ceramic header and stainless header
Old Aug 21, 2007 | 08:50 PM
Gfast's Avatar
hey, what is the different between ceramic coated header and stainless header?
i see the same amount gain of hp, but different prices. are there different material play an important role here?
Old Aug 21, 2007 | 11:00 PM
OCG35's Avatar
Ceramic coated helps with the heat... stainless steel is good for longevity... many get ss and have them jet-hot coated (to address the heat).
Old Aug 22, 2007 | 09:21 AM
Iceman8's Avatar
+ 1
Yes this is correct, I have coated my manifold not only on my G but also a BIG block 454 engine that has lowered temps. Jet-hot and many other suppliers are out there to choose from. The one I have used is SWAIN TECH. They are very well know and have great prices.
swaintech.com
Old Aug 22, 2007 | 12:18 PM
Gfast's Avatar
i am looking at the DC ceramic coated header.
so it is better than the stainless steel one?
Old Aug 22, 2007 | 12:26 PM
GreenGoblin's Avatar
The goblin resurrection
That is what I just did made a huge difference in under hood temps
Old Aug 23, 2007 | 02:03 AM
helldorado's Avatar
Stainless steel that is coated by an aftermarket company tends to have better longevity results than aluminized pieces that are ceramic coated from the manufacturer, but it also costs more in the long run.
Old Aug 23, 2007 | 02:45 AM
Gfast's Avatar
so i should not get the ceramic one than
and go for the stainless steel, but u guys said i need to have jet-hot coated for it.
do i need to do that in order to lower the temp?
or i can just install the header out of the box
Old Aug 23, 2007 | 08:18 AM
Iceman8's Avatar
You can do whatever you want...IF your looking to decrease under the hood temps then yes, you'll want to get the pieces coated no matter what it is made of.
Again check out SWAIN TECH...They are the best IMO. They actually had a magazine do a right up on them with a nissan motor.
Old Aug 24, 2007 | 05:09 AM
Gfast's Avatar
o thanks for the info
so let me clarify something before i will order the part
so i can either get the stainless steel head pipe install and be fine, except that i will get some heat increase under the hood. Unless i get it coated, right?
same with ceramic one too
magnetism80
Jan 27, 2016 12:57 PM
NailBomb
Oct 28, 2015 07:53 AM
AL8782
Oct 3, 2015 10:26 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
