Easiest Way to Reach 300hp from Stock
Old Aug 28, 2007 | 07:34 AM
  #31
Echo6Romeo's Avatar
I always wandered if VDC effects the nitrous when slipping occurs. I assumed if you're spraying and the VDC cuts the engine power then your engine is doomed.
Old Aug 28, 2007 | 09:49 AM
  #32
s2k_g35's Avatar
Put 15K and rebuild the motor from bottom up. I was thinking along that way when or if I have extra money. I read some where about 2 or 3 out of 10 FI got their motor damaged.
Stay N/A.
Old Aug 28, 2007 | 12:07 PM
  #33
Jtrain's Avatar
Originally Posted by M.I.A. BlazinVQ
^^ROFLMMFAO!!
I think your the only one who saw that post.
Old Aug 28, 2007 | 12:58 PM
  #34
GPang's Avatar
how many horses is it at the wheels? if its 293 at the crank?
anyways, like they said above...WHP is what matters.
lets say you have 250 at the wheels...to start off i'd say:
Cold air Intake, Whole exhaust set up (headers to muffler), Pulleys, bigger fuel injectors. 270 whp you might end up with.
its alot of work to get it to 300 whp
forced induction is the way to go. if you want a cheaper FI then go supercharger. Turbos take alot of work and money. Turbos are nice tho.
Its on you.
Old Aug 28, 2007 | 04:07 PM
  #35
Nismo G's Avatar
Turn VDC off maybe?
Old Aug 28, 2007 | 04:54 PM
  #36
ibelonginprison's Avatar
Resident G35Driver Pirate
Originally Posted by Nismo G
Turn VDC off maybe?
Seriously, who's going to spray with VDC on....
Old Aug 28, 2007 | 07:21 PM
  #37
WACK BEATS's Avatar
get a Flux Capacitor and a tune/re-flash from Doc Brown and be done with it !!!! hhhaaha
Old Aug 28, 2007 | 09:06 PM
  #38
DaveB's Avatar
Cheapest and most reliable way to 300whp? Get a different car.
Used STI, used EVO, used 03/04 Cobra, new Mazdaspeed 3, used GTO, used C5, new Mustang GT, used 300C/Magnum/Charger are all capable of 300whp with little to no mods and all can be had for around $25-30K.
Old Aug 28, 2007 | 10:49 PM
  #39
MIA BlazinVQ's Avatar
brb getting cut
but none of those are as sexy as the G
Old Aug 28, 2007 | 11:02 PM
  #40
Joaquin03's Avatar
Staff ALUMNI
that's f***en hilarious...
like, seriously??
Old Aug 29, 2007 | 02:14 AM
  #41
Echo6Romeo's Avatar
you speak as if I'm new to modding. VDC does not fully disable unless you remove the fuse or relay. Turning it off doesn't mean ****. Extreme will spin will cause it to kick in.
Old Aug 29, 2007 | 08:24 AM
  #42
Bimmer G's Avatar
you can also get it to turn off by doin a fast 180. It fully turned off when i was driftin in the rain and spun out.
Old Aug 29, 2007 | 08:26 AM
  #43
Bimmer G's Avatar
Seriously Just do some FI or fully build the build. Bolt on's will any get you ovwer 300 at the crank, not wheels
Freeman186
Sep 6, 2023 10:07 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
