A leak from my plenum?
Old Sep 1, 2007 | 05:45 PM
chinaman_87's Avatar
If there was a leak coming from my plenum would it be loud enough to notice? I did a spacer install and it sounds fine to me so far but just want to double check if there are ways of detecting a leak?
Old Sep 1, 2007 | 06:20 PM
superchargedg's Avatar
The only real way is to use a smoke machine that introduces smoke into the vacumn system to look for leaks.Do you think you have a leak or more important is the car running poorly.
Old Sep 1, 2007 | 07:24 PM
cungkpham's Avatar
you would definitely feel a big notice if you had a leak.
Old Sep 1, 2007 | 08:30 PM
Cux350z's Avatar
If you had a leak, the car would idle rough and maybe even stall.
You should be able to hear the leak if its there. Itll be a loud/high pitched sucking noise.
Last time i removed my plenum and put it back on, i just torqued to spec per the manual with a tq wrench and no leak. so, if you dont have a tq wrench, get one. Itll save you alot of time/headache if you happen to over torque a plenum bolt.
Old Sep 4, 2007 | 11:17 AM
joe603's Avatar
What about the sucking/whistle sound during acceleration (Its hard to tell if its from the filter)? I have the REV2/5/16 spacer and JWT PopCharger. I didn't use RTV on the spacer during the install...could it be that?
Old Sep 18, 2007 | 12:31 AM
well that sucking noise is from the charger. Im guessing I don't have a leak cause its not high pitched at all and the performance seems good. Thanks
Old Sep 18, 2007 | 09:27 AM
Hydrazine's Avatar
If your idle was surging, struggling or rough that is the first sign of a leak. But if your idle is good you don't have a leak.
Idle is the number one way of determining if you do or do not have a leak.
Old Sep 18, 2007 | 01:04 PM
GreenGoblin's Avatar
The goblin resurrection
^ exactly
Old Nov 19, 2009 | 12:37 PM
dt0r's Avatar
Bringing back a dead thread... i just installed my spacer, idle is fine, power seems good but between 4500 and 5200 rpms I hear a whistle(best way to describe it) when I hit the throttle. I saw no mention of this sound in other threads which is why I bring it up...
Old Nov 19, 2009 | 12:49 PM
Hydrazine's Avatar
That's actually quite common and normal.
Its just a larger volume of air rushing past the throttle body plate when the throttle begins to open.
Old Nov 19, 2009 | 01:45 PM
CreativeDesignZ's Avatar
^ sweet! was just gunna ask the same question. I just put on my spacer a few days ago. Friggin love it!
Old Nov 19, 2009 | 02:05 PM
k@osx71's Avatar
what if i'm idling at 650 and when i brake i can feel the car downshifting really rough. rpm also jumps from below 1k for each downshift and i feel the car jump forward very slightly. could that possibly be a leak? i've had the plenum spacer on for over a year combined with a popcharger and ztube. cleaned the MAF and TB also did the idle reset and ecu reset.
Old Nov 19, 2009 | 02:09 PM
dt0r's Avatar
thanks for the reply, makes me feel much better.
ps. i love the product
Old Nov 19, 2009 | 05:00 PM
Hydrazine's Avatar
It could be a leak but the pop-charger can easily do that too. They are known to have issues when letting off the gas.
Also, cleaning the TB is something best left for the dealership. They are really, really sensitive units. It doesn't take much to throw them off and that too can cause the same problem.
Check for a leak at the plenum. If you don't find anything, try checking for other possibilities.
Tony
Old Nov 19, 2009 | 05:50 PM
crashnburn's Avatar
can use a stethascope and listen closely.. i had a slight leak on mine and thats how we found it...
