A leak from my plenum?
Old Nov 19, 2009 | 07:58 PM
k@osx71's Avatar
thanks for the reply Tony! i guess i'll try replacing the popcharger back to oem and see if that helps. as goes for crashnburn's idea, luckily i have a stethascope at home so i'll try that method as well. should i be listening for a faint hissing sound?
Old Nov 19, 2009 | 08:15 PM
Hydrazine's Avatar
Thats a very good way to trouble shoot.
1) Stethoscope. It will hiss when you go over the leak.
2) Try the stock box if its pop-charger related that will fix it.
Old Nov 21, 2009 | 12:04 AM
G35xChicago's Avatar
+1 on the rough idle.
Old Nov 21, 2009 | 06:38 PM
pfarmer's Avatar
Originally Posted by crashnburn
can use a stethascope and listen closely.. i had a slight leak on mine and thats how we found it...
Basically the same method I normally use (short length of garden hose). I have also used freon (makes it stumble) but then that is no longer considered environmentally friendly and is harder to get. A little bit of propane also works as long as you are careful.
Old Nov 21, 2009 | 06:52 PM
crashnburn's Avatar
using the stethascope method u will def hear the leak if u have 1..
Old Nov 21, 2009 | 11:16 PM
SilentAttack's Avatar
I thought I had a leak too but I guess not because my car runs fine.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
hrdwirk1
Oct 2, 2015 06:34 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
vamarris
Sep 26, 2015 12:56 PM
