Alternator pulley help!!!!
I purchased an under drive pulley for rwd vq35de but own a fwd vq35de, will it work and what belt would I use? I didnt pay much so I could always resell it or use it as a paper weight but hoping otherwise.
OK, I'll jump in on this one... If you only got an alternator pulley as your title suggests, use the same belt you had before. If you got a crank pulley (or the complete set) you would need a smaller belt which is available from Stillen (and others).Stillen Underdrive Belt
In that case - I don't know. I would expect it to be the same if it is a vq, but I make no guarantees. You'll find out when you put it on.
brianuc4
19
Apr 10, 2020 02:12 PM
Thebaws11
Nov 30, 2016 12:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
BradMD_96
Oct 6, 2015 09:31 AM
