Mixing oil when oil level is low?
Originally Posted by jin22gt
sorry to veer off the topic but is it just me or does our car have a bad dip-stick? its so hard to put it back into the hole... any of you guys know a trick to put the dip-stick into the hole? i always gotta do it couple of times.
One note of caution, do not put too much oil in it. You can also do damage by putting too much in it. As long as it is between the add and full marks is good.
I always check mine after it has sat all night, before I start it in the morning. That way all the oil has drained down to the crankcase.
Originally Posted by Knightt
Thanks, I'll keep that in mind...will the excess oil eventually burn off? I don't expect my high level of oil is going to last long since I'll be changing the oil this weekend when I get home...I should be okay right?
Phenomenon9
08-09-2015 01:34 AM
TWASkyliner
08-01-2015 11:43 AM
joedaddy1
07-28-2015 02:58 PM
