Check Engine Light
Old Oct 24, 2007 | 01:44 PM
Q45tech's Avatar
The software engineers get better and better in detecting felony emission tampering and protecting you from fraudulently applying for and receiving a passing emission certificate.
Old Jan 2, 2008 | 12:22 AM
G35dxb's Avatar
did you tried 2 pull the batry waire 4 cople of hours caz it might reset the ACU !!!
Old Jan 2, 2008 | 08:09 AM
App6MT's Avatar
Littering and...
What the hell is an ACU?
Rob, did you use 2 spark plug non-foulers? I have an 2006 and have not experienced any problems with it. You may want to pull your positive battery cable (10mm wrench/socket), press the brake pedal in about 10 times (all the way) so that you discharge the capacitors and the stored enery. That is the quickest way I've found to reset the ECU (I have not even attempted the pedal reset).
Old Jan 2, 2008 | 09:00 AM
Skaterbasist's Avatar
Retired SuperMod
Like everyone one asked, did you reset your ECU after the non-fouler install? I would do the pedal method. It's quicker than any other method...takes less than a minute if you do your timing right.
Old Jan 2, 2008 | 09:03 AM
Retired SuperMod
His question has nothing to do with this... we're not trying to trick anyone but the ECU. And the non-foulers are proven to work on many wideband sensor equiped VQ35's
Old Jan 2, 2008 | 08:57 PM
G35dxb's Avatar
sorry iam bad in spelling ... what i meant ECU
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
