MREV2 & Spacers for Non-Rev-Ups??
Originally Posted by Hydrazine
Adding both will raise the A/F slightly, but it doesn't necessarily mean it will be lean.
If you are boarding on lean before the install, then yes, it would push it into lean.
If your A/F is rich to normal before you add it, A/F will be good after installation.
Originally Posted by mpspeer
So by adding just the spacer & not the mrev2, i will not run lean .. only if I do both right? I think I am just going to do the spacer.
Some people have leaned out after just a few breather mods… the only way to know is to dyno with a/f
if all you have is spacer - it's doubful you will be lean
FreshVQ
09-30-2015 01:41 PM
