Please I Need Help!!! For A Motor Swap
PLEASE I NEED HELP!!!
I have G35 Coupe 2003 AT with Salvage title from collision (I Never had a Salvage Vehicle before!!
) I bought this car from EBay , but I make a Big mistake ***I DID NEVER LOOK THE UNDERCARRIGE when pick up this car!!!*** so, when I took it to the shop and put it on the lift we Found that motor had a crack on the block and transmission on belt housing, so I bought a 2005 long block from a salvage yard with this# 883814B VQ35, but the motor is different ON THE FRONT PART! (THE 05 HAVE A SENSORS ON THE FRONT TIMMING BELT COVER, BUT THE NOT THE 03 SO THAT’S THE ONLY DIFERNCE I FOUND SO FAR FROM THE ONE I GOT….), so my question is WHAT I NEED??? in Order to make the 2005 motor work on my 2003 car, so far I think I need a new Wire HARNESS AND MYBE A COMPUTER, SO PLEASE HELP ME OUT I WANT MAKE THIS CAR WORK BUT I DON’T KNOW WHAT ELSE I NEED!!!!
Note: If any of you have an 03 long block and wants to trade for my 05 please call me at (864)-505-4135 my name is Sergio
####THANKS#####
) I bought this car from EBay , but I make a Big mistake ***I DID NEVER LOOK THE UNDERCARRIGE when pick up this car!!!*** so, when I took it to the shop and put it on the lift we Found that motor had a crack on the block and transmission on belt housing, so I bought a 2005 long block from a salvage yard with this# 883814B VQ35, but the motor is different ON THE FRONT PART! (THE 05 HAVE A SENSORS ON THE FRONT TIMMING BELT COVER, BUT THE NOT THE 03 SO THAT’S THE ONLY DIFERNCE I FOUND SO FAR FROM THE ONE I GOT….), so my question is WHAT I NEED??? in Order to make the 2005 motor work on my 2003 car, so far I think I need a new Wire HARNESS AND MYBE A COMPUTER, SO PLEASE HELP ME OUT I WANT MAKE THIS CAR WORK BUT I DON’T KNOW WHAT ELSE I NEED!!!! Note: If any of you have an 03 long block and wants to trade for my 05 please call me at (864)-505-4135 my name is Sergio
####THANKS#####
Other than the harness, you will need the 05 branded ECU. You'll need the engine number to get the correct one. There are several depending on manufacture date of the car. You will need the 05 motor mounts. Also - did the 05 engine come from an AT or MT?
Rick
Rick
Thanks Rick!!!
At this time
i Dont know if the motor is AT or MT mine(03) is AT...i'm going have to call back the Guy from the Junk yard to get the Vin# for this motor, the only number i have is the one stamp on this wich is 883814B VQ35
Thanks
i Dont know if the motor is AT or MT mine(03) is AT...i'm going have to call back the Guy from the Junk yard to get the Vin# for this motor, the only number i have is the one stamp on this wich is 883814B VQ35 Thanks
Originally Posted by G-DRAGON
At this time
Thanks
Rick
thechitoguy
Oct 1, 2015 05:25 PM
