Need to change fluids
Old Nov 6, 2007 | 08:18 PM
Scrooge's Avatar
Hello everybody. I was wondering if you knew what other type of fluids can I use for the G35 beside's the nissan fluids. The fluids I need to know of are:
Power steering fluid
Automatic transmission fluid
Differetial fluid
Thanks if you can help
Old Nov 6, 2007 | 08:42 PM
cmthresher's Avatar
im not sure what brand. But i just took mine to the dealership and they changed all of mine and put syn. in the whole car. You can call a dealership and ask them what kind of syn. they put in their cars.
Old Nov 6, 2007 | 09:09 PM
sloppymax's Avatar
Differetial fluid
the only fluid i know that is highly recommended to stay oem with is the auto transmission fluid or matic j. i have seen some oil manuf. sites that showed they had equivalents for it now but i currently do not know anyone that has tried it. you can use dexron/mercon 3 auto transmission fluid for power steering or any equialent, (mobil 1 atf, etc.) the diff oil you just need something close the oem weight and GL5. i used mobil 1 75w-90 with good results. nissan does recommend their coolant as it has a low silica count but i have used the all brands prestone with no negatives. brake fluid should just be dot 3. these recommendation can be backed up in your manual or by checking the esm/fsm.
Old Nov 6, 2007 | 09:12 PM
Hi-TechG35's Avatar
There's plenty of fluids. Valvoline, Royal Purple, Motule etc.
Old Nov 6, 2007 | 09:49 PM
Scrooge's Avatar
I know there is plenty of fluids, But some can damage the parts and make things go bad.
Hawk196
Sep 22, 2015 02:51 PM
Eomfd
Aug 29, 2015 12:42 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
linedr89
Aug 17, 2015 05:11 PM
NemesisGee
Aug 11, 2015 07:10 PM
