JWT S7 Revup camshafts and Top Secret 100mm throttle body...
Old Nov 18, 2007 | 02:19 AM
AS007's Avatar
I have a 2005 G35 Sedan 6mt w/ Injen CAI, Headers, Test Pipes, Borla Cat-Back, Mrev2, 5/16" Thermal ISO. I want some more power and I am thinking about buying the JWT S7 camshafts but I have not seen or heard anything about a revup motor and cams.. I also found a 100mm Billet Aluminum Large throttle body sold for $1,275.00 which seems like a lot and was wondering if there were any other large throttle bodies out there, and what kind of gains you can get with one. And last but not least I saw the Top Secret Individual Throttle Body setup for $6,090.00 any thoughts on that??
http://www.topsecretjpn.com/products/100mmtb.jpg
http://www.topsecretjpn.com/products/vq35itbx.jpg
Old Nov 18, 2007 | 02:48 AM
rookie's Avatar
For that kind of money just get boosted.
Old Nov 18, 2007 | 12:40 PM
AS007's Avatar
True, I'm not really planning on buying the individual throttle bodies but I was just wondering exactly what they do.. I don't want to turbo my car, I was hoping to get close to 300rwhp NA and leave it at that. So I was wondering if camshafts, throttle body, and utec would take me there..?
Old Nov 18, 2007 | 04:27 PM
jonnylaw's Avatar
u need more than that on the vq; ie port/polish, valvejob, rods, etc. Or at least a stroker kit.
Old Nov 18, 2007 | 04:56 PM
godmans's Avatar
get an utec and tune your car first..then you can start touching on the internals =)
Old Nov 18, 2007 | 09:40 PM
g35ctuner's Avatar
and then
Old Nov 19, 2007 | 01:08 PM
Q45tech's Avatar
Measure [with a precision manometer] the pressure drop across your existing TB at HP peak rpm probably around 6-7" W.C. or 7/27.7 or 0.25 psi............that's 1.7 % restriction, if a new larger TB cuts that in half you would/could gain 0.8% x 300HP or 2.4 HP.......maybe 3 on a lucky day.
Supercharging is a separate case because the TB restriction rises with 30% more air flow.
The entire restriction from atmosphere thru every intake component is less than 6%. Why few mods actually do much so little to start with so little restrictions stock.
Old Nov 19, 2007 | 04:31 PM
AS007's Avatar
Ok, so has anyone installed cams on a revup motor?
Old Nov 19, 2007 | 04:33 PM
Jeff92se's Avatar
Red Card Crew
I really think a reflash would be the best bang right now.
Old Nov 19, 2007 | 05:48 PM
DaveB's Avatar
On this site? Probably only 1 or 2 guys. You'd have better luck on the my350z.com site. Keep in mind that cams will trade low to midrange power for topend breathing. Cams increase breathing efficency therefore you'll need to get a reflash to increase the rev limiter to ~7500rpms. I'd also recommend adding deeper gears because with the stock gearing, the gears will be too long plus you'll have less lowend power and you'll need the torque multiplication to make up for the difference. The cams will also require different springs and buckets, but those may be included in the cam costs. Overall, you're looking at about $1000+ for the cams, $300 for the springs/buckets if not included, $1,000 for install, 3.7 or 3.9 gears plus install $1,000, and a reflash $400-800. Overall, you're looking at $3,400 to $4,100 to do it right.
Old Nov 19, 2007 | 06:06 PM
JdM_G35's Avatar
my friend made 304 whp on his z.
intake, headers, motordyne, nismo cams, test pipes, tru dual, emanage. i think thats it. non rev up z too. on a dynamics.
linedr89
Aug 17, 2015 05:11 PM
g35_anonymous
Forced Induction
Aug 14, 2006 11:16 PM
Gman2004
May 26, 2005 08:00 PM
