braided hoses?
Old Nov 27, 2007 | 12:49 PM
KapVu's Avatar
braided hoses?
Is there such thing as stainless braided hose kit for the G35? I've search and can't fine any. I like the stainless braided look with the chrome locks. I was hoping to replace all the VAC lines and maybe the radiator hoses too.
Can anyone let me know if there's a kit? Thanks.
Old Nov 28, 2007 | 12:09 AM
KapVu's Avatar
anyone? I did more research and found there is no kit, but what is a good brand of stainless steel hoses to use to replace hose lines? Thanks.
Old Nov 28, 2007 | 11:24 PM
OCG35's Avatar
PM SoCalTed - wait till next week though, he's swamped with an event this weekend that his car club is hosting.
Old Nov 30, 2007 | 08:01 PM
rookie's Avatar
Dam I forgot to get back to you on the hose pm. Sorry man.
I used Earl's perform-o-flex around the engine bay.
Summit carries it in bulk. I'll warn you ahead of time on the pricing.
Example of getting 10ft of -10 http://store.summitracing.com/partde...5&autoview=sku
Than fittings -10 fitting http://store.summitracing.com/partde...5&autoview=sku
The hoses add up, the fittings add up. Some shops may carry stock that can be cut down as needed. But your car may be down while you're trying to get the pieces cut to fit. I bought bookoo to make sure I had enough to do my engine bay, still have more to do and I've got enough to start on my buddies engine bays as well.
Old Nov 30, 2007 | 08:24 PM
OCG35's Avatar
how does one become a buddy? - I know, I know... first a bumper now braided hoses... Anyway, how does one become a buddy
Old Mar 10, 2008 | 08:32 PM
SoCalTed's Avatar
if not going for shiney, I'd suggest Earl's pro-lite 350 for light weight and zero abrasiveness, plus you won't need as many 45 or 90 degree connectors.
Kinda hard to get points for at shows if you are not there to point them out. Pretty stealthy.
One thing though is that you aren't supposed to use it iwth brake fluids. The other teflon lined hoses can be used. ALTHOUGH... I had my hoses installed by Earl's team (not holley) and they did use a couple on my master cylinder. 30k later and no issues.
So here's the break downs on braided hose:
EZ Flex Hose:
* 304 Stainless steel braiding
* SAE-30R7 rubber smooth bore inner core for oil, fuel & emission lines
* Lightweight and extremely flexible
* Used for low to medium duty (100 PSI MAX) applications
* Operating temperature range to 250ºF
* Easy to assemble
* Avail in sizes ID .3125" & ID .375" (Stainless Steel)
Diamond Lite Hose:
* PET Monofilament braided for maximum hose protection
* Easy to assemble
* Avail in ID: .25", .3125" & .375"
* Avail in Red, Blue or Yellow Braid on Black hose
Earl's Auto–Flex Hose
* Stainless Braid
* Protects Synthetic Rubber Hose
* See Catalog Page Above For Operating Pressures
* Remains Flexible at Temperatures Between -40°F and +300°F
* Competitive Price
* Meets USA Specifications
* Textile Braid In Hose Liner
* Clean and Fast Flowing
* Avail in:
Size 3, ID .15625, OD .375
Size 4, ID .21875, OD .4375
Size 5, ID .25, OD .5
Size 6, ID .34375, OD .546875
Size 7, ID .375, OD .625
Size 8, ID .4375, OD .640625
Size 9, ID .5, OD .71875
Size 10, ID .5625, OD .796875
Size 11, ID .625, OD .875
Size 12, ID .6875, OD .9375
Size 14, ID .75, OD 1.03125
Size 16, ID .875, OD 1.15625
Size 18, ID 1, OD 1.3125
Size 28, ID 1.5, OD 1.84375
Size 32, ID 1.75, OD 2.125
Earl's Prolite 350:
* Highest Pressure Lightweight Rubber Lined Hose Available
* Half the Weight of Traditional Stainless Braid Hose
* Maximum pressure rating of 350 psi
* 1400 PSI Burst Pressure
* -40° F to +300° F Operating Temperature Range
* Holds 27 hg Vacuum
* Constructed In USA
* Abrasion Resistant Nylon Sheath
* Easy to Cut and Work With
* Synthetic Rubber Liner
* Incredible Flexibility
* Withstands Hot Oil Temperatures
* Avail in:
Size 4, ID .22, OD .44
Size 6, ID .35, OD .55
Size 8, ID .44, OD .65
Size 10, ID .57, OD .80
Size 12, ID .69, OD .94
Size 16, ID .88, OD 1.16 (optional inner support spring avail)
Size 20, ID 1.12, OD 1.70 (optional inner support spring avail)
Perform-O-Flex:
* Stainless Steel Inner Braid
* High-Temp. Synthetic Rubber
* Maximum Pressure Rating of 250-1500 PSI
* Mechanical Bond Between Layers
* Provides Constant Flow
* Full Coverage Outer Braid
* Avail in sizes:
Size 20, ID 1.125, OD 1.4375
Size 24, ID 1.375, OD 1.703125
Size 28, ID .4375, OD .640625
Ultra Flex 650 - SS braided
* Covered in aircraft quality 304 grade stainless steel wire
* High-Temp. Smooth bore Teflon® tubing
* Maximum Pressure Rating of 740-1180 PSI
* Convoluted outer wall of inner tube for incredible flexibility
* Remains Flexible at Temperatures Between -94°F and +510°F
* Bend radius of 1.772"
* Avail in:
Size 6, ID .394, OD .512
Size 8, ID .536, OD .650
Size 10, ID .658, OD .819
Size 12, ID .780, OD .961
Size 16, ID 1.0039, OD 1.272
ULTRA Flex 650 (KEVLAR):
* Ultra-light Kevlar® Outer Braid
* Maximum Pressure Rating of 740-1320 PSI
* Remains Flexible at Temperatures Between -94°F and +500°F
* Avail in sizes:
Size 4, ID .220, OD .378
Note: Max PSI ratings differ depending on diameter of hose.
Old Mar 11, 2008 | 11:43 AM
waijai's Avatar
i.love.gold
I've priced it out, and it can get very expensive.
Old Mar 11, 2008 | 12:25 PM
OCG35's Avatar
how expensive?...
Old Mar 20, 2008 | 03:35 AM
425skyline's Avatar
one......... billion dollars....
alessandro
Oct 8, 2015 09:29 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
G35CO
Sep 4, 2015 09:27 AM
