Idler Pulley Removal Mod with Pics
Old Jul 28, 2011 | 01:11 PM
  #91
Frankieg35's Avatar
Does anybody have a spaced they wanna sell??
Old Jul 28, 2011 | 04:56 PM
  #92
MyGeeeee35's Avatar
I'm gonna be doing the mod this weekend. I'll make up a bunch of spacers out of aluminum on Monday. I'll post when I get em done.
Old Nov 22, 2012 | 11:59 AM
  #93
blockbleeder's Avatar
the idle pully
ok so i have a 03 g35 coupe did as followed worked with no problems.only 1 problem the belt you posted was a 1" 1/8 to big .or its my light weight stillen pullys i have .no clue not done yet will post when i am finshed with the job and will post pics for you 03 g35 boys to fill safe that it does work.cya ya soon
Old Nov 23, 2012 | 10:18 AM
  #94
TurTLe*'s Avatar
sounds like your stillen pullly might be underdriven.
Old Jul 18, 2015 | 10:28 AM
  #95
Abram827's Avatar
I have the 04 G35 what are sizes for both belts I got confused I thought I had only one belt?
Old Jul 20, 2015 | 09:27 AM
  #96
LoSt180's Avatar
Nissan removed the pulley in 07, hence why a factory spacer is available.
Just ask for 07-08 FX35 belts and you should be fine. There's 2. 07 G35 coupe belts would work also, but the 07 Sedan had a different engine and some stores might not have accurate info in their databases (ie accidentally give you 07 sedan belts instead of 07 coupe belts).
Old Aug 11, 2015 | 10:23 AM
  #97
joedaddy1's Avatar
FYI... my 2003.5 sedan has the fan connected to that one pulley..
Old Jan 29, 2016 | 11:46 AM
  #98
YoungGuwap's Avatar
Do you by any chance still have the idler pulley assembly?
Old Apr 29, 2016 | 09:51 PM
  #99
SlideRyder's Avatar
steppin up the pulley game
So my question is has anyone deleted more than just the powersteering idler pulley only? Say for instance the a/c idler pulley or the alternator idler pulley or even all 3 extra pulleys but keep the main ones? Just use a shorter belt, less weight, less drag on motor and less bearings to worry about going wrong? Any drawback or anyone tried this before?
Old Apr 29, 2016 | 10:16 PM
  #100
SlideRyder's Avatar
The goal is daily driver with a/c and powersteering but to drop the extra weight and problems down the line with all the extra parts. I've been playing with the idea for sometime and maybe it might be something worth looking into. Any input would be appreciated.
Old Apr 30, 2016 | 12:29 PM
  #101
LoSt180's Avatar
The pulley in this post is the only one you can delete and keep all of the accessories functional. The other two pullies are what puts tension on the belts. Without them you wouldn't be able tighten up and secure the belts. You can theoretically delete the a/c by just removing the belt but that won't meet your needs.
Just delete the one extra pulley and be done with it.
Old Nov 19, 2016 | 10:33 PM
  #102
twitch's Avatar
I'm changing my belts and decided to remove the idler pulley. The pulley assembly was really tight to wiggle out from between the PS bracket and motor. I finally got it out with a mallet but now I cannot get the spacer in at all. I've tried using screwdrivers, pry bars and other things but that bracket will not budge.
Is there a trick or other tips that might help in getting the spacer in there? I also loosened the bolt behind the PS pulley but still no luck.
Did anyone else have also issue getting a spacer back into the slot?
Thanks!
skippyG
Jan 25, 2016 01:18 PM
linedr89
Aug 17, 2015 05:11 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
