Check engine light on after MREV2
Old Dec 11, 2007 | 07:29 PM
lekker_droom's Avatar
My Check Engine Soon light came on today about 50 miles after getting work done on the car. I had the MREV2 installed yesterday and had dismal dyno results. Not saying its the MREV in anyway, but rather something with the install...
Anyone else had this happen?
Tony from Motordyne gave me some suggestions to tell the shop that installed it but just curious if others had this issue and what was the solution.
Old Dec 11, 2007 | 07:39 PM
QuadCam's Avatar
you need to check the OBD2 port with a scanner to see what the code is.
That is the first thing to do!
there shouldn't be any reason to get a CEL with that mod. trust me......I have had my manifold on an doff my engine so many times, I have the torque sequence memorized along with the torque specs for each bolt. I've never had a check engine light, either.
Old Dec 11, 2007 | 07:41 PM
UnluckyCharms's Avatar
Where are you located? Maybe get someone else who's installed a spacer to take a look at it, since the shop may not have installed it right. My spacer went on fine, no issues.
Did they reset the ECU? Any chance they dirtied up the TB, or messed up the TB sync?
Thanks for responding but what is a CEL?
Old Dec 11, 2007 | 07:42 PM
Just talked to the shop, told me to bring by in the morning.
Old Dec 11, 2007 | 08:31 PM
CEL = Check Engine Light
Old Dec 11, 2007 | 08:32 PM
D'oh!
Old Dec 11, 2007 | 11:30 PM
By the way, it's the Service Engine Soon light.
Old Dec 12, 2007 | 11:22 AM
joe603's Avatar
Are you sure you reconnected all the appropriate vacuum lines?? Check your work, then reset the computer. (disconnect the negative battery terminal, and depress the brake pedal)
Old Dec 12, 2007 | 12:20 PM
Code was run and supposedly was the 02 sensor. Took it out and dried it and light went away (it's been raining for a few days here). Just coincidence in timing I guess...
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
