V8 conversion for a G coupe....
Old 12-12-2007 | 04:06 PM
atownpdx's Avatar
So... I know some other infiniti cars (M & SUV) come with V8's. Has anyone seen a thread or know of someone that has put a V8 in a coupe? Even did a google search and came up dry.
There is no way I am the first person to have this idea. Do you guys know of anything out there?
and if money was no object I would add twin turbos to the deal (and new drivetrain, tranny, rear end and brakes ofcourse). Can you imagine?
Thanks
Old 12-12-2007 | 04:15 PM
Alan's Avatar
the topsecret g has a v8.. i think somebody on this board is doing it also. i forget who
Old 12-12-2007 | 04:16 PM
GrayG35's Avatar
dam this idea crossed my mind so many times. drop a 5.6 v8 out of a titan and do turbo, exhaust, and tune. man the g would move! imagine what people would think. you pull up to the light next to a c6 z06 and rev, then he says i thougt thought those cam with v6's lol
Old 12-12-2007 | 04:19 PM
atownpdx's Avatar
I'm drooling now. That would be soo sahweeet!
That's what I found. A V8 from a totaled Titan. So now I just wana talk to someone that's done it or doing it?
Old 12-12-2007 | 04:21 PM
citymunky's Avatar
Old 12-12-2007 | 04:32 PM
atownpdx's Avatar
cool thanks citymunky
Old 12-12-2007 | 04:38 PM
Klubbheads's Avatar
I don't think it would be a good idea. Sure it will be fast in the straits but what about taking turns. G's front is already heavy imagine how much a V8 would through off the balance of the car.
Old 12-12-2007 | 05:44 PM
sloppymax's Avatar
there are a handful that i have seen over on my350z, the logistics of the swap should be extremely similar. the latest i saw was an ls1 or ls2 swap, the motor ended up weighing only 60lbs more of which about 35 lbs could be offset by relocating the battery to the trunk.
Old 12-12-2007 | 06:22 PM
Klubbheads's Avatar
^wow only 60lbs, i would think LS1 or LS2 would be heavier than that. If its 60 lb it isn't that bad consider what u said, relocating the battery to the trunk.
Old 12-12-2007 | 06:28 PM
helldorado's Avatar
VK isn't no heavier than a VQ with a TT kit, its all aluminum and not much larger. Most TT kits add 75 a quick lbs to the front of the vehicle.
Old 12-12-2007 | 06:35 PM
surfwb86's Avatar
Old 12-26-2007 | 09:36 PM
mailhot's Avatar
I am doing two Titan VK5.6 G35 coupes. One with the Stillen SC and one with ITBs. Are you in Atlanta?
Old 12-27-2007 | 02:38 AM
reconJDM's Avatar
I think Chris Forsberg of Drift Alliance is rocking a V8 Titan motor in his 350z convertible.
Old 12-29-2007 | 05:12 AM
adrenaline rush's Avatar
Big thread of an LS2 swap into a 350Z
http://www.my350z.com/forum/showthread.php?t=310010
Lots of power, torque, and easy to upgrade. And fuel economy would probably be the same
Old 12-29-2007 | 06:48 AM
fast04G's Avatar
q45 motor..i plan on attacking this one..if i can get my hands on one. build it up and TT..kinda like the mean build a member here is doin..good luck btw!
Quick Reply: V8 conversion for a G coupe....
