blew my motor....parts help
Originally Posted by kuwait_G35
checked it ... it was crank sound
now am planing to buy pistons which it over size .40
and rings and bearings ..
what do you reccomend ?
Also, how loud is this tick? Is it really loud or only marginally audible from the outside with the hood closed? The reason I ask is if the sound isn't extremely loud, the sound could be the injectors. The injectors on these cars are really loud and always have been on VQs. As rpm is increased, the injectors tick more often. A simple test is to turn the engine on, warm it up, and then take a long screwdriver and place the metal end on top of the injector cap and place the handle up against your hear. Have someone rev the motor a couple times (idle to 3000rpms) and listen to the sound. If the sound a louder version of what you're hearing with the hood down, then it's the injectors. I can't tell you how many times people have mistaken the injectors for a serious engine problem.
no bro , now am sure that its crank
thnx 4 the advise
alot of guys advise me to buy
1- CP Pistons, VQ35DE, 96mm Bore, 11.0:1 Compression
2-Eagle H Beam Rods VQ35, VQ35de
3- bearings
for daily use drive, maybe am thinking to get nos
what do u think guys ???
thnx 4 the advise
3- bearings
Originally Posted by sharif@forged
I think you should take the advise I gave you over the PM.
Here to help!
Here to help!
i will take it but tell me somthin can i use NOS ???dose the engine be safe ??
ok mr.sharif
