Humming noise for 1-2 miles
Old Jan 21, 2008 | 07:38 PM
damafuka's Avatar
I've done the search and no luck. After a cold start i notice a hum that sounds like a window leak but it only last for 1-2 miles and then its gone for the whole day. this happens everyday. Its annoying. Does any one have the same problem and is there a fix for it?
Old Jan 21, 2008 | 08:49 PM
Dubfound's Avatar
Mine dose the same! Kinda like a humming/whine sound right?
Old Jan 21, 2008 | 09:43 PM
delaseouL's Avatar
Mine also hums/whines.
Strange.
Old Jan 21, 2008 | 10:42 PM
accordfreak's Avatar
I had the same issue. my 6mt transmission was changed under warranty.
Old Jan 22, 2008 | 12:48 AM
Gsmurf's Avatar
Hey I had the same problem. The dealership changed the transmission fluid to a lighter one and now the noise is gone. They said if i hear it again, they would give me a new tranny. Try to change the fluid first.
I have a 6mt too. did you have problems shifting into gears when you had this issue?
Old Jan 22, 2008 | 06:27 AM
damafuka's Avatar
yup problems shifting gears... this sucks. i just went over my warranty. i guess i can change the fluid.
Old Jan 22, 2008 | 07:39 PM
Dubfound's Avatar
What state are you located in? I think mine only does it when its cold. $hit now you have me thinking my trans is effed up. Guess it cant hurt to bring it down for a checkup.
Old Jan 22, 2008 | 07:55 PM
yeah the noise goes away after the car is warmed up. you can hear it cruising around 35-40 mph. the tone of the sound changes as you accel/decel. i'm in nor cali
Old Jan 22, 2008 | 08:08 PM
partyman66's Avatar
Does it do it only when in gear... or will it still do it if you coast in neutral from 35-40 MPH?
Old Jan 22, 2008 | 08:43 PM
it's been awhile but I believe when it's out of gear coasting at 35-40mph, it doesn't make the noise
Old Jan 22, 2008 | 08:47 PM
here's what it stated on the work order:
"client claims that there is a howling noise coming from the transmission in the morning during the first 10 min driving L4. Road test vehicle and confirmed the complaint. Found trans. noise internally. Complete replacing trans."
Old Jan 23, 2008 | 01:36 PM
delaseouL's Avatar
I don't have any problems shifting gears, but it does make the whining/humming sound during the first 3 to 5-minute drive in the cold weather. I started hearing this noise after I changed my clutch, which was 2 weeks ago. My warranty is also up.
Old Jan 23, 2008 | 02:01 PM
Hotnikks's Avatar
That sucks for you as I'm pretty sure it's your tranny hummin like that. If you've documented it before the warranty was up you should have a leg to stand on
Old Jan 23, 2008 | 08:11 PM
Dubfound's Avatar
I am bringing mine into the dealer on Monday night and leaving it overnight so the can hear the noise for themselves in the morning when they start and move it. I will keep you posted on the BS they tell me.
Old Jan 24, 2008 | 11:22 AM
V35 Skyline GT's Avatar
6MT Coupe
Mine does this too, has since new. Kind of sounds like a mild SC whine but it's the gearbox. Mine hasn't gotten any worse and shifting has stayed the same, actually better shifting running Amsoil. But if it does get worse, warranty will handle it.
