P1283 - possible fixes ?
Old Jan 27, 2008 | 05:49 PM
myGspot's Avatar
THe other day the car finally threw the code P1283. I have the non-foulers on my t-pipes and had them installed since day one when i installed the t-pipes. I have been running this set up for 2 yrs. now but never had any problems until now.
I searched on here but did not come across any long term problems that people have running non-foulers. Is there a reason why after 2 yrs the code would pop up?
Can the o2 sensor be cleaned at all or does it have to be replaced?
I know my car is burning oil as well, so could this have also caused the problem? (burning oil residue depositing on the o2 sensor)
How long can you drive the car with the code being like this or does the sensor need to be replaced ASAP? Is there any long term damage that can be done to the car / performance if the sensor not swaped out?
Old Jan 27, 2008 | 10:45 PM
Mr_pharmD's Avatar
it may just be bc the weather is really cold. Do what homie said and reset your ecu and it should go back to normal. Chances are it's due to the weather being too cold than normal and the ecu is pulling a code.
Old Jan 28, 2008 | 02:07 AM
myGspot's Avatar
doesnt the code specify that the car is running lean vs rich?
anyone know what o2 sensors of other nissans/infiniti's fit on our cars?
Old Jan 29, 2008 | 04:43 PM
Jeff92se's Avatar
Red Card Crew
The 02s will definately be affected by oil and the t-pipes. I do believe you can clean them and reinstall. Just be gentle and don't knock them around too hard.
Old Jan 29, 2008 | 04:47 PM
myGspot's Avatar
any idea what they can be cleaned with?
Do i use any cleaner or alcohol on it or should i just may be use a wire brush?
Old Jul 12, 2010 | 04:59 PM
Nor_CalG35's Avatar
Did you ever get this fixed?
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
NyCrAzY
Oct 1, 2015 09:19 AM
