i have a 04 sedan. without buying an aftermarket exhaust, is there anyway to make it sound like the coupes
Will when i took off my stock exhaust. I put my stock mid pipe onto my boys sedan and he said it sounds a little bit deeper. The resonator on the coupe is alot smaller than the sedan.
^^ That's it! The coupe midpipe does pretty well. You can get test pipes, or hi flow cats. That'll help a little (test pipes may give you a raspy sound at certain RPM though)
