05 G35 Sedan Oil
Old Mar 25, 2008 | 01:42 PM
jeffco_0147's Avatar
05 G35 Sedan Oil
I am getting ready to change the oil in my 05 for the first time, and was wondering if anyone knows how much oil to refill it with. I will be replacing the filter as well during this. In searching the threads, the best i can find is 5.25 qts. Is that correct? thanks for the help!
Old Mar 25, 2008 | 05:20 PM
Beebo's Avatar
yeah 5qts.
Old Mar 26, 2008 | 09:46 AM
geronimomoe's Avatar
I assume you either bought the car used or this is the first time you did it as a DIY and it was changed regularly in the past, correct?
I'd like to add to what Beebo said above.. Put in 4.75 quarts first, wait a few minutes then check the oil level. Add oil as needed to bring the oil level up to the full line on the dip stick. You don't want to overfill.
Old Mar 26, 2008 | 12:03 PM
LudwigB's Avatar
What kind of oil are you planning to use? From what I've read, Mobil M1 0-40, Amsoil 5-30, and Castrol Syntec are among the best.
I had 5 quarts of Royal Purple and that was enough.
Old Mar 27, 2008 | 10:48 AM
risingson's Avatar
thread jack.
ima being doing my first oil change since ive had my car soon too.. ive got 39k and i want to use synthetic or a synthetic blend.. which oil should i consider, and do i need to know anything about going to synthetic (im assuming im not running synthetic now)
Old Mar 27, 2008 | 11:48 AM
LudwigB's Avatar
Originally Posted by risingson
thread jack.
This should give all the info you need:
http://www.my350z.com/forum/showthread.php?t=258663
Old Mar 27, 2008 | 03:24 PM
ttrank's Avatar
Grocery getter
With my greddy pan and AAM spacer I run 6.5qts of M1 15w50.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
lemmy999
Jul 25, 2015 12:13 PM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
