Oil Filters
Old Apr 3, 2004 | 07:47 AM
DHCrocks's Avatar
Oil Filters
I just bought some Mobile 1 M-108 filters for my car and was shocked to see how small they are. I can't believe that a 3.5 V6 would have a filter this small, it looks like it should be on a moped or something. I was just wondering if the stock filters were similar in size. This will be my first oil change so I don't know how big they are.
Old Apr 3, 2004 | 11:03 AM
rrowen's Avatar
Re: Oil Filters
I purchased K&N oil filter for mine. I was also shocked at the size. Yes, that's it. I checked out Fram & Nissan's filter to see if they were the same & they are.
'03c6mt/Blk/Premium/Aero/Eibach's/Hyper-Grounding
Ztube+JWT/Injen SES/Rogue Shortshifter/Momo/Sparco
Old Apr 3, 2004 | 11:13 AM
hotg35's Avatar
Re: Oil Filters
Do a search. Subject has been discussed ad nauseum, and links given to filter ratings.
Old Apr 3, 2004 | 05:24 PM
lowrider's Avatar
Re: Oil Filters
Yes me too. I use K&N also. When I saw how small is was (the HP-1008) I called K&N Technical. The Tech told me the HP-1006 is a little longer, a bit larger in diameter, but has the same pressure specs. It fits fine, and I've been using the HP-1006 with no issues. IMO, K&M oil filters are tops.
Lou
Old Apr 3, 2004 | 08:00 PM
Msedanman's Avatar
O.F. Administrator
Re: Oil Filters
The Maxima filters are slightly larger. I use them (recommended by the dealer).
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Apr 4, 2004 | 01:24 AM
khsonic03's Avatar
Re: Oil Filters
Use the M1-110 it is slightly larger with the same pressure valve. Mobil 1 filters are better than K&N because the use a synthetic fiber vs a paper element which is less likely to break down/ clog. They also have a higher filtering percentage vs K&N.
'03.5 Silver AT Sedan, Premium, Aero Kit/Package, Sport, Winter, Stillen Air Box, Z pipe, Polk Tweeters, Clifford RSX 3.5, Gram Light 57F Pro's (on the way), Hotchkis sways, Borla
Old Apr 5, 2004 | 12:45 PM
TooFast4U's Avatar
Re: Oil Filters
On pressure tests, however, M1's have been noted to sometimes cause a fairly large drop in pressure due to the restrictiveness of the filter. K&N's have been tested w/ almost no drop in pressure.
Also, K&N does use a synthetic media as well.
It's probably fine either way, but given the small size of the filter, and the fact I wanted to run extended drain intervals, I chose to go with the K&N 1006 to avoid any potential pressure problems, particularly on extended drain intervals.
I've used M1's in other cars though with good results - so like I said, it's probably okay either way. Purolate Pure One are also great filters too - very high filtering percentage, about the best out there, but same thing, sometimes cause a drop in pressure as well.
Old Apr 5, 2004 | 12:55 PM
khsonic03's Avatar
Re: Oil Filters
TooFast--Do you own a 2003 cobra?
K&N does not use a synthetic filter element, unless they have just started VERY recently. It is a resin-impregnated paper element. Do you have a link that says it is synthetic, because if so, that is news to me. The tests I have all seen have confirmed that it is paper.
Old Apr 6, 2004 | 12:43 AM
thegr8tg35's Avatar
Re: Oil Filters
Want to learn about oil filters? Go to
http://theoildrop.server101.com/ubb/...?ubb=forum;f=6
those guys are serious...BTW, check out the thread "BOBISTHEOILGUY FILTER TESTS", it shows various filters tested...(Looked how the M1 dropped in pressure)...
Old Apr 8, 2004 | 02:54 AM
augie's Avatar
Re: Oil Filters
What do you guys think about the Nissan filters? Think it would be okay to use that filter with synthetic oil?
Old Apr 8, 2004 | 01:21 PM
ryoken's Avatar
Re: Oil Filters
The Nissan filters are perfectly fine, and a safe choice if you're unsure about which aftermarket filter to go with. After all, it's the one Infiniti recommends for the car.
Aftermarket filter sizes were discussed here: My first oil change! -- along with part numbers for different brand replacement filters, OEM size and the larger size.
Can any confirm whether the K&N part number for the larger filter size is 1006 or 1010? Then I can update that list and put a copy of it in the FAQ section.
<P ID="edit"><FONT class="small"><EM>Edited by Ryoken on 04/08/04 10:25 AM.</EM></FONT></P>
KruZZe
Feb 27, 2023 05:04 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
