gas milege
Re: gas milege
The best I ever got was around 24 mpg.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Re: gas milege
24 - 26 with no BMWs, Mustangs, Subbies, Acura's, Toyotas, Hondas, or wanna be lexus' around.
~ or 13 - 16 with a lead foot and some mods that growl.
-T
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
-T
Re: gas milege
i avg. 19.7 mostly city driving. on the highway, i've gotten up to 26.
2003 G35 Sedan 5AT
{Z-Tube} {JWT_POP_Chrgr.} {V1} {21%_Tint} {Matte_Race_Pdls} {Blck_w/Grpht_Lthr} {Prm_Pkg.} {Sprt_Tuned} {Wntr-Sprt} {Nav.} {Xenon} {Sunroof} {Aero-Body_Kit_w/Spoiler} {Trunk_Mat}
2003 G35 Sedan 5AT
Re: gas milege
The best I ever got 99% highway was 21 from Portland to Seattle to get service and back. Average speeds were 65-80. In mostly city driving, I probably averaged 14-15.
Re: gas milege
i dunno about you guys, but i have navigation. what this allows me to do is view my gas consumption in real time. so when i am driving on the highway or local roads and i am just cruising, i lift off the gas pedal just enough to give me at least 25/mpg.
it helps a lot because you just don't realize how much gas is being consumed with the slightest touch of the pedal.
2003 G35 Sedan 5AT
2003 G35 Sedan 5AT
Re: gas milege
wow u guys are getting some good mileages....i average at around 15 thats including highway driving...too??
Re: gas milege
I don't do much highway driving, but I recently had to travel from one side of town to the other and got 150 miles on the last 1/4 of gas. It was right on the last 1/4 marker and I drove it until the needle was just below the empty line. That comes out to 30 mpg if you assume 5 gallons for the last 1/4 marker.
Re: gas milege
one more point i noticed...the g35 seems to be calculating the gas mileage on my car according to a 18 gallon tank. the 2 gallons might be "safety" gallons. whenever i fill up, it shows 360 miles remaining when i avg. 20mpg. so, maybe you guys are actually getting better mileage than stated.
2003 G35 Sedan 5AT
2003 G35 Sedan 5AT
Re: gas milege
I'm a little upset with my mileage. I have a Coupe w/auto 5-speed.
I've only had the car a couple of weeks, but I'm driving very conservatively and getting 20 mpg. The specs on Infiniti's website say the car should do 18/26. I do a lot of highway driving and I'm at 20??
I had a BMW 325i prior the the G35. That car was rated 20/29, and I was getting 26mpg all the time.
I expected to lose some mpg with the Infiniti, but had hoped to keep the actual close to 23-24mpg. Maybe that's not realistic.
Maybe the mileage will improve slightly after the engine wears a little?
Thoughts?
Thoughts?
Re: gas milege
No, Infiniti lists mileage for the 5-speed at 18/26, and the 6-speed at 20/27.
It just seems that they were optimistic at best, if not downright misleading.
I may be speaking too soon. I'll give the car a few thousand miles and an oil change before it bugs me, but still. . .the BMW 3-series numbers seemed much closer to the truth.
Re: gas milege
Mine has 23k and still quite low mpg my friend has the same exact car even the color is same (if that makes a difference) with 3k and still similar mpg of 16/21.
You should not expect it to go any higher if you already have over 2k miles
2003 G35 Black Sedan
Re: gas milege
I drove from Houston to Pflugerville (just north of Austin)
today and then back. I bought mbarrad's HKS rear section
exhaust. I logged 23.7 mpg for over 400 miles. Thats
pretty good for me!
12 wire Grounding kit, 350Z duct, Stillen CAI
HKS rear section exhaust
pretty good for me!
