Help me please any ideas?
Old May 23, 2008 | 02:20 PM
EricIsKlumzyee's Avatar
but it sounds DAMN nice =D
Old May 24, 2008 | 02:52 PM
aLi-KaT's Avatar
Originally Posted by Gordgee
In the interim, if you want more aggressive sound, some have removed their 'Power Duct' and say it sounds better.
the power duct?? where is that?
Old May 24, 2008 | 02:54 PM
aLi-KaT's Avatar
Originally Posted by Hydrazine
The biggest increase in sound will come from the pop charger. If you then add a 1/2" spacer to it, the sound will become substantially more than the stock sound.
The combination of the two is not subtle at all.
If a Z tube is also used, the sound level begins to approach the definition of "Loud".
At least thats my opinion on it.
what's the difference with the 5/16' spacer and the 1/2' spacer? which one should i use?
Old May 24, 2008 | 03:05 PM
blackstorm's Avatar
The 1/2 is a bigger spacer therefore giving you a little bit more power, but when i say little i mean like 1-2hp, however with the 1/2 you wont be able to have the engine cover on, so most ppl settle for the 5/16 and sacrifice the 1-2 hp so they can keep the engine cover on.............
Old May 24, 2008 | 03:07 PM
aLi-KaT's Avatar
so 5/16' it is.. lol thanks
Old May 24, 2008 | 11:26 PM
Gordgee's Avatar
Administrator
Lift the hood and you'll see the 'Power Duct' (actually labeled by Nissan) attached to the front of the air-box. Just push the center of the 2 pins in and lift up.
Old May 25, 2008 | 01:30 AM
Hydrazine's Avatar
I don't recommend that though. For performance reasons.
It draws in a lot of hot air.
Old May 25, 2008 | 01:38 AM
Gordgee's Avatar
Administrator
I probably agree. Does give a bit more sound however.
I found the Pop-charger was very poor for performance as well! So much so that I took it off after about 2 weeks and went back to the stock box. Great for sound, but not much else.
Old May 25, 2008 | 09:06 AM
Hydrazine's Avatar
Stock intake FTW.
Old May 25, 2008 | 09:39 AM
aLi-KaT's Avatar
So I changed to the z-tube and took off the back part of the air box and put on the pop charger... I like it and I can feel the power when I accelerate. It sounds a bit meaner… now i just gotta order the spacer lol.. one thing at a time...
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
hrdwirk1
Oct 2, 2015 06:34 PM
wow600rr
Sep 28, 2015 11:50 AM
Jcruzg35
Sep 26, 2015 04:47 PM
