Can someone Clarify for me?
Old May 2, 2008 | 11:57 AM
hipi2002's Avatar
I greatly appreciate the information that this forum has to offer but in some cases, it kind of reads like stereo instruction. My clarification is in regards to the MREV2 lower collector. I plan to buy an 03 or 04 Sedan and I would like to know would it Benefit for the model I plan to acquire or should I just stick with the 5/16" spacer? I'm not trying to go for extreme HP, primary reason...GAS PRICES , but I would like to enjoy the feeling of being able to stomp on the throttle and feel her move. I have already made plans to go with a Borla exhaust and a Popcharger with a Z-tube. I'm also not trying to nickel and dime hP, I am just trying to see where I can with it. I know in order to get the full potential of all my parts a tune must follow. Please to all, help me understand for my fragile brain is starting to smoke,
* Also can someone tell me the difference in a high rev as suppose to a non-highrev?*
Old May 2, 2008 | 12:10 PM
Skaterbasist's Avatar
Retired SuperMod
You can always get it, but the MREV2 shines on the revup motor.
You might want to watch out for your AFR if you get the spacer + MREV2 if you already have a few mods.
Old May 2, 2008 | 10:21 PM
Gordgee's Avatar
Administrator
Don't bother with the MREV2 on the '03,'04. It'll benefit the revup, but little on the older engine as it's basically a slightly modded lower plenum that's already there.
Also, unless you just want a bit more noise and possibly lose a bit of power, don't do the Pop-charger. I had mine on for a couple of weeks before I went back to stock. Most CAIs do little or may do worse on the G35.
Old May 3, 2008 | 12:47 AM
hipi2002's Avatar
what's the diff between revup and non-revup?
Old May 3, 2008 | 12:48 AM
hipi2002's Avatar
So would I be fine with a spacer and that's it being that I'm just trying to get descent hp gain?
Old May 3, 2008 | 01:03 AM
SDGenius's Avatar
just get the MREV2 not the spacer. it'll give you much better returns in TQ and only slightly less HP(in comparo to the spacer, still good gains over stock) up top. don't run them both on ur Non-RevUp, you'll run really lean w/o a tune.
Old May 3, 2008 | 03:41 PM
hipi2002's Avatar
What could I gain realistically with the spacer alone, and would I still have to tune if I put one or the other on? I would still plan to tune in order to get the full potiential performance of the parts for example, exhaust and intake. What I am wanting to know is what can I get away with installing on the Sedan before having to tune, and if there are parts I can install before relying on a tune, will I see a noticible gain in any hp?
Old May 3, 2008 | 08:43 PM
SDGenius's Avatar
okay, as far as bolt-on's go... you can bolt on all the parts you want w/o a tune. you just won't get the max potential of any of them, you may even lose HP & TQ. w/just bolt-on's w/o a tune, you'll most likely lose power down low and add more up top. it'll feel a lot more powerful BUT it'll be due to a few spikes in mid/high range. your actual peak power will only be up by a few(prob less than 5) ponies. i just finished w/my bolt-on's and got a Technosqaure reflash & custom tune, i couldn't be happier. the car was a lot more raw w/o the tune(kinda fun), but after it was a lot more smoothed out and now just keeps pulling well after 100mph. here's my perfomance bolt on parts list, hope it helps...
Engine/Exaust:
-JWT Popcharger w/Blitz SUS filter
-ARC intake pipe
-Motordyne 5/16" Iso-Thermal plenum spacer
-AMS light wieght pulleys
-HKS Twin Power DLI-II ignition amp
-Stillen grounding kit(silver)
-NGK Iridium spark plugs(one step colder)*
-Stillen engine damper
-DC Sports ceramic coated headers
-Kinetix High-Flow Cats
-Stillen Generation 2 dual-path cat-back exhaust
-Technosquare ECU reflash & tune
(*)recommended by Technosquare after my tune, still needa get 'em installed
Old May 3, 2008 | 11:06 PM
hipi2002's Avatar
Engine/Exaust:
-ARC intake pipe
If you don't mind me asking, but how much did your tune cost?
Old May 3, 2008 | 11:09 PM
hipi2002's Avatar
Also, did you get a dyno of what your hp and tq was after everything was tuned?
Old May 4, 2008 | 06:08 PM
SDGenius's Avatar
The tune was $550 for basic reflash plus $150 for custom dyno tune. yeah, after the tune it was 246whp & 240wtq. i picked up like 18hp and much broader/smoother tq band. i wasn't immediatly impressed w/the numbers but then i found out that stock 03 G35 sedan 5AT's dyno around 210 on their dyno i felt alot better. they told me that on another dyno on another day i could add 20hp+ to my chart, with no new mods(add 10 more when i get new plugs). so i'm not too concerned about the numbers. i'm more pleased w/the extra 18 ponies or so and the smoothed out ride. i should be pretty close to 300hp to the crank w/some killer high-end grunt. my car sounds & moves so much better now, it's crazy. don't get too caught up in peak numbers or dyno charts for that matter, just pay attention to ur actual gains and you'll be good.
brooklynite
Dec 15, 2006 05:50 PM
KIDG35
Dec 12, 2006 10:39 AM
Sportcoupe35
Aug 19, 2005 01:02 PM
whoojong
Feb 10, 2005 06:47 PM
