Service Engine Light
Old Jun 19, 2008 | 05:39 PM
jusdtip's Avatar
Alright my service engine light came on and i took it to autozone and they told me it has somethimg to do with the gas cap or a vacuum leak of some sort. So i buy a new gas cap light is still on and cant seem to find any leaks anywhere. I have a cold air intake and full tanabe exhaust. Can my fellow g35 lovers help me PLEASE! Thanks mike
Old Jun 19, 2008 | 07:05 PM
xnyc's Avatar
do you have a actual code number? im assuming your talking about a evap leak.
Old Jun 19, 2008 | 09:21 PM
jusdtip's Avatar
yes but they never told me the code. i did this reset for the ecu that i have seen on these post and it works so far. also the person i bought the car off of says he took it to the dealership for the same reason and they were suppose to fix it BUT i guess not
Old Jun 20, 2008 | 12:34 PM
kaisar's Avatar
I just went through the same situation. I took my G back to the dealer. They had to replace the throttle body. I also have a 03. They will hit ur pockets if you are out of warrenty. But since then everything is working normal now.
Old Jun 21, 2008 | 10:59 PM
jusdtip's Avatar
how much was that?
Old Jun 30, 2008 | 02:53 PM
kaisar's Avatar
how much was that?
The dealership will ask around $600.00 without a warranty. You should check and see if that is covered under the warranty, if not you should look at the aftermakets spots. It will be cheaper.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Ednica87
Sep 5, 2015 02:59 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
