engine starts - doors lock
Does anyone know if the '04 G35X can be programed to lock the doors with the engine starts or when the car's in drive?
Better question: Where would a relay be placed to do this? Between the starter and window power down?
<P ID="edit"><FONT class="small"><EM>Edited by korz on 04/24/04 09:41 AM.</EM></FONT></P>
Re: engine starts - doors lock
get the window control mod that allows you to roll your windows up with the oem remote and you can have the auto door lock.
Daniel
5ATC / DP / Willow / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window Up / VDC Memory
Daniel
there is a super long post about it in this (tech forum).....window up with oem remote
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, double 15% tint
that went no where..
Does any technical type know where to place a relay in the starter circuit - window power down circuit to make the doors lock when the ignition is started?
sometimes, i'm not sure why i even bother replying with pertinent info.
i dont know either red, but i guess ill help him out. here is the link to the window mod. https://g35driver.com/forums/showfla...&sb=5&part=all
i think the only way your goin to get it is to get that or make one yourself.
Daniel
Daniel
It would be feasable to use a relay on the starter wire to lock the doors everytime you start the car.
Standard Bosch relay:
Pin 85: Starter wire
Pin 86: Ground
Pin 30: Ground
Pin 87: Door Unlock (Usually Yellow wire inside drivers door)
You might also be able to use the actual door lock motor wires coming from the BCM but that would be a lot more difficult. I believe there are 4 wires total (2 wires for drivers door motor and 2 wires for all other door motors). This is a 5 wire, reverse polarity system. Due to the complexity of this I won't go into more details unless you want me to.
Oh yeah, I guess I should tell you to buy a window mod too.
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
RE Short Shifter // Z Tube
Pin 86: Ground
Pin 30: Ground
Kevin
thanks for the replays.. that post was sooo long I didn't get to the solution until the third time I went down it. I'll try a pre-order. again thanks.
will091195
Jul 27, 2015 09:19 PM
