NEED Advice, I'm visiting the Dealer for Repair?
Old Jun 27, 2008 | 12:07 PM
3Point5Sedan's Avatar
Ok, I did an AC check myself since I knew there was something wrong, as I suspected the condensor has a hole, most likely from a rock, i have an extended warranty and the AC condensor is covered, however they made it clear there only going to cover defects, not wear and tear, to which I replied than why have it listed on the warranty, there is no other way the condensor could ever cause problems, it's that simple of a piece.
So I'm bringing it in Monday morning, so they can run their diagnostics that will tell them what I already know.
Question, HOW do I get around this wear and tear ****?
Any adivce on what angle to use as reasoning that they should fix it anyways?
Can I say they sold me it like that, does it matter if they did?????
Old Jun 29, 2008 | 11:39 AM
xnyc's Avatar
get some ac refrigerant dye and run it along the seam of the condensor. when they test for a leak theyre gonna see the dye around the seam thinking the seam is leaking=manufacturer defect
Old Jul 1, 2008 | 08:55 AM
Nice good idea, how do I run it along the seam though, it's hard to reach, do I need to move the bumper?
Old Jul 17, 2008 | 03:51 PM
mediumred91lx's Avatar
Sorry to jump in this so late but...
Any dealership will try to pressure test this first, and when they see a large amount of dye spraying out of the condensor like exhaust from a jet engine that will equate to you buying a condensor and/or paying for diagnosis time.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
B03Sedan
Sep 22, 2015 10:37 PM
DRG35R
Sep 16, 2015 05:33 AM
Jyounya
Sep 12, 2015 04:03 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
