High Idle After Cleaning?!
Old Jul 14, 2008 | 11:01 AM
whipyahead's Avatar
I have the same problem, if the throttlebody was broken from moving the butterfly then the car shouldnt hold an idle and stall out ?
Old Jul 14, 2008 | 11:45 AM
Hydrazine's Avatar
Not necessarily. It depends on how far off the calibration is.
Old Jul 16, 2008 | 03:49 PM
elrooko's Avatar
Hey guys - I had this exact problem. I think I figured out why some have problems cleaning their butterfly valves and others don't. Tony is bang on, it depends on how far out of calibration the butterfly sensor is. If it is too far out, then the pedal reset procedure doesn't work. You need to either use an autoenginuity, or a Cypher to initate a Master Settings Reset I think it is called. Once you do that, you can do the Idle air volume learn, and the butterfly throttle open procedures.
This is what happened to me - I cleaned my butterfly valve and immediately was getting a high idle and throwing a P0507 code. I assumed the valve was toast but when I did the throttle position reset, it worked great until I shut the car off and restarted it, then it seemed to loose it's settings. I went to the dealer, they did the master reset, the IAVL and the thottle position reset and it has worked great ever since.
They charged me a half and hour labour so I was only out $50 bucks. Anyone with a Cypher or autoenginuity can initiate this themselves without going to the dealer.
Old Jul 16, 2008 | 04:09 PM
OCG35's Avatar
another thing to consider... for those that clean without removing the TB - make sure to disconnect/unplug the throttle control actuator... also during a reset the FSM states it should be unplugged when performing the procedure...
Having these plugged in could be why some people didn’t find resolution...
Old Oct 17, 2008 | 07:58 PM
cutiewolf's Avatar
go to autozone or any other shop.. they got the scanner and clear the codes for free or small bill....its very simple thing..going to dealer and get it reset is waste of money IMO...disconnect the battery and let it sit there over night will reset the whole computer... i might be wrong someone correct me if im wrong...
Old Dec 26, 2008 | 02:35 PM
BRY82BRY's Avatar
throttle
easy way tp clean the throttle body//////
have someone in the car, turn ign to th on position(engine off duh)
have the driver put the car in drive or 1st gear/ depress the accelerato and the buurtfly valve will open.. now the person outside of the car can clean th carbon build up around the inside of th tb//// just dont touch the butterfly//
Old Apr 20, 2009 | 05:37 PM
JoeMac's Avatar
You can easily clear the codes yourself, thats not a problem. I tried disconnecting the battery and it didn't seem to work for me... pumped the brakes and everything. Here's how you clear the code.
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
esotericrider
Feb 14, 2022 07:19 AM
Silver tiburon
Sep 4, 2015 07:17 PM
yankeefix
Lighting
Aug 24, 2015 04:12 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
