First time changing oil, Need help ASAP
Old Jul 12, 2008 | 02:50 PM
Nickk6's Avatar
So I am doing my oil change myself for my first time since I now have my own 2 post lift . Problem is I told my mechanic buddy to get my mobile 1 synthetic oil and he got me 0W-40, is that ok? I asked him for 10w-40, but oh well. Any recommendations
Old Jul 12, 2008 | 02:52 PM
mIKE's Avatar
um.... 5-30 or 10-30 is what you really should be using unless you're FI and havn't told us.
40 is just too thick, and you're only robbing yourself of HP and MPG.
Old Jul 12, 2008 | 02:56 PM
Nickk6's Avatar
Thanks, glad I am doing the oil change myself because if he did it he would have just thrown the oil in their with no concern.
Old Jul 12, 2008 | 05:14 PM
lexusk8's Avatar
While you're under there doing the oil change, get yourself a power drill to unscrew the black plastic engine under cover. This will allow access to the oil drain plug and oil filter. The cover is held on by 12-15 screws/bolts, and with the power drill you can remove them all with the drill without tiring yourself out.
Old Jul 12, 2008 | 05:30 PM
my05g35sedan's Avatar
Better yet
Better yet while it's off cut a 3x5 access hole and you'll never have to remove it again.
Old Jul 12, 2008 | 10:17 PM
bythabay's Avatar
the 0w40 will be fine, no worries.
Old Jul 12, 2008 | 10:36 PM
firefox's Avatar
I've been using M1 0W-40 since last winter. My car seemed to start up a lot better in cold weather. Pretty good year round oil and still okay for the track. Cold starts may not be a concern in CA though.
http://my350z.com/forum/showthread.php?t=258663
Old Jul 13, 2008 | 10:02 AM
ttrank's Avatar
Grocery getter
0w40 is fine.
Old Jul 13, 2008 | 10:17 AM
RBull's Avatar
Rated M
^+ 1
Old Jul 13, 2008 | 06:57 PM
superchargedg's Avatar
Even though i am FI 0w-40 will be fine and an improvement on what you use.
Old Jul 14, 2008 | 11:26 AM
Nickk6's Avatar
Haha, thanks for the tip. I have a powered lift, of course I am using power tools on that stuff.
I ended up using the 5w-30 since that was what infiniti recommends. I will put the 0w-40 in next time and compare. There was no noticeable change switching from castrol synthetic to mobile 1.
Old Jul 14, 2008 | 01:27 PM
lexusk8's Avatar
There shouldn't be any change when switching oil brands. Of course switching synthetic to non-synthetic (and vice versa) is perfectly OK. You may notice a difference in gas mileage too but it will be very slight.
Old Jul 14, 2008 | 03:19 PM
Nickk6's Avatar
Yeah I am watching my mpg, there is no difference there either. Guess the Castrol with 4500 miles on it was doing fine.
Old Jul 14, 2008 | 03:22 PM
Nismo G's Avatar
0w-40 is fine...here read this.
https://g35driver.com/forums/engine-drivetrain-forced-induction/178003-vq-oil-analysis-info.html
-Sean
chinee
Jun 10, 2024 07:48 PM
ghost_g35
Aug 7, 2015 10:31 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
lemmy999
Jul 25, 2015 12:13 PM
ClwMike
Jul 23, 2015 12:55 PM
