fujitsubo Y pipe compatibility
Old May 2, 2004 | 01:04 AM
esemes's Avatar
curious:
will the Fujitsubo "y" pipe fit the oem exhaust system correctly???
i was under the impression the overall dimensions (length & spacing) were correct, but the ID of the single pipe section was larger....
how then, i ask, would this work to the oem unit??
((saw an ad that stated it will work w/ oem))
anyone have any experience w/ this part??
im also interested in their midpipe/muffler setup, but not right away....
thanks
scott
Old May 2, 2004 | 01:07 AM
esemes's Avatar
Re: fujitsubo Y pipe compatibility
for example, see below....
esemes's Avatar
doh!
Old May 2, 2004 | 11:49 AM
Gsedan35's Avatar
You can bolt them together. What happen's to the flow at that point, wouldn't take much to figure out. But as you say, you plan on getting a system down stream latter on that will use larger pipe diameter to match up proper. Unless the timeline to upgrade the piping down stream is a awefully long one, I wouldn't worry about it.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old May 2, 2004 | 04:19 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
the y-pipe will fit the oem mid-pipe. though the diameter is larger, the flange is smaller, thus making the bolt locations the same as stock.
like gsedan35 said, since you're getting an aftermarket midpipe and muffler later, you won't need to worry about going from small (cats) to big (y-pipe) back to small (midpipe).
Golden Gate G35 Club
Old May 1, 2005 | 10:46 PM
Gsedan35's Avatar
That's the way to do it, but why are you selling?
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
