Radiator Caps function clarification
Old Aug 21, 2008 | 06:52 PM
UR2EZ's Avatar
so let me get this straight... "Because the thermal efficiency of internal combustion engines increases with internal temperature the coolant is kept at higher-than-atmospheric pressure to increase its boiling point. A calibrated pressure-relief valve is usually incorporated in the radiator's fill cap. This pressure varies between models, but is typically 9 psi (0.6 bar) - 15 psi (1.0 bar)."
so the coolant in the radiator is pressurized to keep it cooler, and the radiator cap releases excess pressure at a certain point. the higher the 'bar', the more pressure is allowed in the tank... correct?
just wondering cuz where i live it's freaking hot, and these Nismo caps are only $30 at a place here... so is it worth it?
Old Aug 21, 2008 | 07:29 PM
bora28's Avatar
correct
suby01
Not G35 Related
May 25, 2016 03:07 PM
BradMD_96
Oct 6, 2015 09:31 AM
vamarris
Sep 26, 2015 12:56 PM
