Help With This Issue....
Old Sep 10, 2008 | 09:12 AM
JDMG35SPORT's Avatar
any reason why my vdc off, brake and airbag light wont turn off?, this is happening while im driving. This happened last week as well but i resolved the issue by turning off and on the car a few times.
The vdc off light doesnt turn off ,neither does the brake light nor the airbag light, is this a sensor problem? i havent had any previous problems with the car at all an i sure's hell aint going to infinity so they can charge me an arm and a leg to check or run a diagnostics test...can anyone help!!!??
the lights came off after turning the car on and off a few times...but i wanna know whats causing this issue so i can have this resolved if it happens again
Old Sep 10, 2008 | 09:29 AM
it happened again this morning!!!
Old Sep 10, 2008 | 09:38 AM
thatguy II's Avatar
for the VDC and brake light make sure the brake fluid is topped off, if it's near the lower line it will trip the float switch.
Old Sep 10, 2008 | 09:40 AM
ill check on that i think the level is lowe rthan it should be, so this might be the issue
Old Sep 10, 2008 | 10:41 AM
vhtran's Avatar
Hope this will make sense. Last time happened to me when I installed the after market entertainment system. Which I used 1 of those wire tap to the foot brake to turn the video on while car in motion. Some cars only 1 sensor switch under there, our cars have 2 and I didn't even notice it so I tab to 1 of them and the switch went bad which causing that problem. Had my dealer replace w/o charged.
Old Sep 10, 2008 | 12:12 PM
Masta Splint's Avatar
I would run down to your local auto zone store they can scan your car for free and let you know what the codes are. Then just post the code on the board and we will help you out. I work for Infiniti so I know they will charge you a lot you scan that but I might be able to help you with the codes. PM me if you want.
Old Sep 10, 2008 | 12:29 PM
vhtran's Avatar
^^not the engine light up. can't pull code from those
Old Sep 10, 2008 | 12:56 PM
ill see if that will help, the lights are off now but its been two times already that this has happen and its starting to worry me a bit
Old Sep 11, 2008 | 08:17 AM
this happened again this morning, BUT i did make the mistake of mentioning that the air bag light was one of the lights on but it wasnt, the SLIP light is on while i drive, the vdc off light is on and the brake lights are the only light on not the airbag one as previously stated...should i just run a diagnostic check on this?
i did notice the brake fluid is at the minimum line...not sure if this has anything to do with that or not, this only happens in the morning, i just turned off the car for a quick second turned it back on and the lights went away...wtf!!!???
g35gti
Feb 1, 2013 02:03 AM
03GT35R
Feb 27, 2012 10:08 PM
BlownKoop
Sep 28, 2011 01:31 AM
RedVines
V36 Brakes, Suspension, Wheels & Tires
Oct 21, 2010 09:41 PM
