Over Heating ?
Old Feb 11, 2012 | 12:34 AM
03GT35R's Avatar
Over Heating ?
After 224k my oem radiator got a small leak in the top plastic end tank. Other than smelling coolant & checking the fluid once a week with no other issues...
So i ordered a Mishimoto Radiator for it & Installed with no issues. Now the gauge is saying it is running hot according to the stock gauge. I know these are not 100% accurate by any means and dont tell you the actual temp, which sucks imo! Although i dont think its really running hot bc of replacing the single core with a dual core it should be running cooler at this point! I just cant see how before i changed it i wasnt having any cooling issues & now i changed it for an upgraded all aluminum radiator with 2x the size it starts to overheat.
I started to check a few things out.
First check for any leaks, none- Checked amount of coolant level, seems to be full and have a little extra in the overflow tank. Then i checked the fan clutch & found the fan clutch was bad, when i turned the engine off the blade would keep spinning freely and it wasnt engaging...So i Replaced with a new fan clutch tonight, still same issue....(gauge says its running hot)
Next I thought maybe the thermostat was sticking or just flat out bad so i changed the thermostat out tonight as well...Same issue, running hot (according to the gauge).
Could the coolant temp sensor be bad?
Would a bad fan clutch cause the water pump to go bad?
Thanks Guys!
Old Feb 11, 2012 | 04:41 AM
kpowe1's Avatar
Are you sure all the air is out of the system, I had mine changed and it was a pain getting all the air out. I ended up taking it to the dealer after NTB couldnt do it and my car kept over heating.
Old Feb 11, 2012 | 08:42 AM
03GT35R's Avatar
I am not 100% sure that all the air is out the system. I have bleed the vent valve and left it run at idle for about 15-20 mins at regular idle rpm, then i held the rpms at 2000 for about 5 mins.
How do you tell if you have all the air out?
Old Feb 11, 2012 | 10:45 AM
kpowe1's Avatar
Not sure, with mine I attempted to vent the air myself. I let it idle for minutes on end and idled it to 2grand and it wouldn't over heat at all but as soon as I started drive ( 15 + minutes) it would start. I knew mine had air in it when I cut the heat on it wouldnt blow hot just warm. Once I got on the gas it would start blowing hot but when I went back to idle it would blow warm again. I could also hear liquid slashing around when I started from a stand still.
Old Feb 11, 2012 | 07:31 PM
03GT35R's Avatar
Yeah thats exactly what mine is doing with the exception of i dont hear anything inside under the dash thru the heater core...I havent messed with it at all today as i was at work, but i m planning on bleeding it again 2 mrw.
Old Feb 12, 2012 | 05:43 PM
kpowe1's Avatar
Cool, difficult problem to deal with I end ed up taking mine to infiniti ine cost 120. Good luck
Old Feb 12, 2012 | 06:41 PM
superchargedg's Avatar
Its a pita but you def have air in the system.The bleeding procedure is a ita but do a couple of times and youll get the air out.
Old Feb 12, 2012 | 09:21 PM
03GT35R's Avatar
Yeah it had a crap load of air in the system, i bleed it all out today...took a few hours to get it all out...but seems to have been the issue....
Old Feb 22, 2012 | 11:38 AM
JZ's Avatar
JZ
G35 Coupe KY0
Wow, im curious to find out what your problem is as well... I just replaced the water pump at the dealer this weekend. Not cheap! But before i turned it in to them, i swapped the thermostat myself so I wouldnt have to deal with bleeding the system myself since they were going to do it anyway.
Im only at 77k and my waterpump went out. Maybe because i didnt do the coolant service on my car for 2 yrs. FML!
Old Feb 25, 2012 | 08:53 AM
djamps's Avatar
These cars are a pita to bleed.
Old Feb 27, 2012 | 10:08 PM
03GT35R's Avatar
I didnt have to replace my water pump, just needed to bleed all the air out and yes its a MAJOR PITA!
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
