2nd gear
Old Sep 18, 2008 | 01:12 PM
  #31
lara04silver's Avatar
oh and i looked up the free loaner car. its only good during the standard warranty. and i think you have to be 21 years old? but i plan on going there in a couple hours to talk to them in person
Old Sep 18, 2008 | 02:27 PM
  #32
uf20wop's Avatar
yeah i think you have to be 21, they asked me that when i took my g in
Old Sep 18, 2008 | 02:28 PM
  #33
uf20wop's Avatar
my dealership must be cool though, they didn't ask any questions, just replaced everything and called me in 8 hours when it was done
plus i got to drive around in an 08 g35 sedan, which felt faster then my 04 g35c
Old Sep 19, 2008 | 09:09 AM
  #34
soooo i went to infiniti tomorrow. i told him everything that was happening like the 2nd gear was grinding or it felt like i was hitting a wall before it went into gear. he said it could be the synchros, clutch going, or tranny. don't really think it's the clutch or maybe just don't want to cause its $1200 for a new one or $2400 if i need a flywheel as well. he said the synchros are covered under warranty and that the lubricated? parts of the tranny are covered. how did you guys get new clutch or tranny under warranty? he said there was no way they would replaced it!
Old Sep 19, 2008 | 09:43 AM
  #35
uf20wop's Avatar
weird! i took my car in, went for a test drive and the tech felt the grind too, and then they just ordered me a new tranny... later on they called me during the tranny install and told me they were replacing the flywheel, and clutch assemblies under warranty also. i didn't even have to do anything.
try another dealership maybe
Old Sep 19, 2008 | 10:34 AM
  #36
is the grinding and difficulty to get into second really signs of a dying clutch. i mean sometimes it shifts in fine if i hold the clutch a second longer than normal when shifting. i would think more synchros/tranny. or maybe i just wanna think that cause its gonna cost 1-2 grand for new clutch. AHHH
Old Sep 19, 2008 | 11:11 AM
  #37
uf20wop's Avatar
it's probably the synchros
the tranny shouldn't grind at all if the clutch is fully depressed.
Old Sep 19, 2008 | 11:13 AM
  #38
thats why the guy at infiniti thought that the clutch might be slipping if when i have the clutch to the floor and its still grinding into second. first gear seems fine.
Old Sep 19, 2008 | 11:29 AM
  #39
uf20wop's Avatar
well each gear has it's own synchro, so your 2nd gear one might be busted
in which case you get a w hole new tranny, cause infiniti dealerships don't rebuild them
Old Sep 19, 2008 | 11:42 AM
  #40
can't they just replace the 2nd gear synchro though?
Old Sep 19, 2008 | 11:45 AM
  #41
ohh i see what you mean but the infiniti guy said that synchros are under warranty. ahh im confused now. would infiniti replace the tranny under the powertrain warranty if thats the case?
Old Sep 19, 2008 | 11:49 AM
  #42
uf20wop's Avatar
yes, if it is a synchro problem infinti will just replace the whole transmission under warranty
  #43
uf20wop's Avatar
and you might get lucky like i did and they might just end up replacing the clutch and flywheel under warranty also
Old Sep 19, 2008 | 03:37 PM
  #44
uf20wop's Avatar
any updates?
Old Sep 19, 2008 | 05:52 PM
  #45
Doruk's Avatar
i am waiting for an update as well , cus i have the same problem and they said i might need to buy a clutch as well because they wont do it under warranty so whatever comes out i will make my move according to that. and i they replace the clutch and flywheel as well is it possible that you can scan it and post it here so i can go and show it to my dealer as well
