Does anyone know if drive belts are covered under the manufacturer's warranty? I had a squealing sound coming from the engine and brought my car to the dealership. Now they are telling me that my drive belts need to be replaced and it will cost $180.
Anybody know?
Anybody know?
Quote:
Thanks man. Is it common that these need to be replaced? I only ask because the car only has 30,000 miles on it and I haven't seem much mention of them on the boards.Originally Posted by ttrank
No they are not. They are a wear item like clutch, tires, etc.
Thanks again for your reply.
I just bought this belt set below last night from Riverside Infiniti for $29.
http://cgi.ebay.com/ebaymotors/ws/eB...076825198&rd=1
if one or both of your drive belts has snapped it is considered warrantable, but at that point you will probably be over the 60K
no. they may show crack, but it's still good.Originally Posted by xosder
Thanks man. Is it common that these need to be replaced? I only ask because the car only has 30,000 miles on it and I haven't seem much mention of them on the boards.Thanks again for your reply.
my belts were/are cracked for 30k+ miles now..
I'll have to check this out. Are you installing yourself or bringing it to someone?Originally Posted by Kazaam35x
I just bought this belt set below last night from Riverside Infiniti for $29.http://cgi.ebay.com/ebaymotors/ws/eB...076825198&rd=1
Not sure if they're cracked or not but there is a high pitch squeal coming from the engine. I probably need to replace them soon and it's getting pretty annoying listening to that sound but definitely don't want to pay $180 to have it done.Originally Posted by joedaddy1
no. they may show crack, but it's still good.my belts were/are cracked for 30k+ miles now..
Quote:
oh the sounds.. sorry.. maybe it needs belt tension adjustmentOriginally Posted by xosder
the g is notorious for belt squeeling. It gets loose quite often and needs to be tightened
Quote:
Never had that problem with mine except when I had my Stillen SC. Otherwise I have installed 3 sets of belts and then re-tighten a couple days later. That's it.
