Turbo XS UTEC vs UpRev Osiris
Old Oct 5, 2008 | 04:58 PM
mikeman2459's Avatar
well i have an 05 6mt coupe with test pipes, cat-back, mrev2, 5/16 spacer, z-tube, and pop charger. Which would be a better investment for me i dont foresee FI anytime soon and im looking to beabel to drive it normally but i alos want the extra power when i need it
Old Oct 11, 2008 | 09:45 PM
Karma779's Avatar
Hi, I have an 06 AT coupe. I have a 5/16 spacer, full cat back Stillen, injen cold air intake, high flo cat, unorthodox crank pulley. I'm very new to this, what is a n MREV2? I want to get as fast as possible without forced induction.
Old Oct 11, 2008 | 09:52 PM
_jb's Avatar
_jb
Photographer
UpRev's Osiris is a great way to go with an NA car. The UTEC is still somewhat acceptable for FI cars, but is generally not used for NA cars an longer.
MREV2 is a modified 287hp lower plenum designed to give more lower and mid range power to revup engines. You have an AT so you don't have a revup, so it wouldn'y be a big improvement for you.
Old Oct 11, 2008 | 09:55 PM
dofu's Avatar
20 Year Member
You can't really compare the UTEC to the Osiris... one's a piggy back, the other is a reflash. In other words, one is still tricking your ECU while the other is a reprogrammed ECU...
Old Oct 11, 2008 | 09:56 PM
Karma779's Avatar
What would you suggest I add to make it faster?
Old Oct 11, 2008 | 10:03 PM
dofu's Avatar
20 Year Member
If you're looking to tune your car, I would suggest Osiris over UTEC.
Old Oct 11, 2008 | 10:24 PM
_jb's Avatar
_jb
Photographer
Yea, either get Osiris or a standalone, but don't fool with a UTEC on an NA car.
Old Oct 12, 2008 | 12:25 AM
i might just forget all of this and just go s/c or turbo. do i need a new hood with a s/c?
Old Oct 12, 2008 | 05:16 AM
dofu's Avatar
20 Year Member
Only the Stillen. You can use Osiris even if you're boosted... it's got a lot of really great features including multiple maps that are selectable by using your cruise control buttons, and it doesn't interfere with your cruise control functions.
Old Jan 2, 2009 | 12:44 AM
Tollboothwilley's Avatar
What are the issues with the early 2003's as far as using the Osiris?
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
