Bad Engine/trans Mounts
Old Oct 11, 2008 | 05:05 PM
AARONHL's Avatar
How can I tell if my engine and transmission mounts are worn/bad/need to be replaced?
Thanks,
Aaron
Old Oct 11, 2008 | 05:54 PM
jjyellow's Avatar
for engine mounts, you can try to power brake your car in drive and reverse and check to see if the engine jumps up a bit or is held pretty solid in the engine bay. as far as a tranny mount gota prob take it off to see.
Btw if you have a bad motor mount for an 03-05 I have 2 mounts for sale if needed
Old Oct 11, 2008 | 06:15 PM
dofu's Avatar
20 Year Member
Trade em out for solid mounts... those don't need to be replaced unless you seriously broke something...
Old Oct 11, 2008 | 08:08 PM
AARONHL's Avatar
I will try that test. So you are saying it's a rarity?
My car jerk/bucks when I get off the gas pedal after speeding up a little. My clutch isn't slipping and the SES is off. Any chance you know what it is?
Old Oct 11, 2008 | 09:42 PM
joedaddy1's Avatar
where is the engine mount on a 1G G35?
anyone know what page on the service manual it's on?
i think my MIGHT be bad too.
Old Oct 11, 2008 | 09:48 PM
AARONHL's Avatar
What are your symptoms?
Old Oct 11, 2008 | 10:42 PM
joedaddy1's Avatar
very very very minor vibration on the gas pedal @ 40~50mph range... the tires are balanced..
Old Oct 12, 2008 | 01:31 AM
AARONHL's Avatar
I think I have that too....
Old Oct 12, 2008 | 12:32 PM
joedaddy1's Avatar
o yea.. the main thing is.. say i am going ~50mph and then let go the gas.. there would be a FAINt/SLIGHT "jefk" and then when i hit the gas it would jerk a LITTLE bit also..around 1.5~2.5rpm
similar to say if had your car at 5k+ rpm and gas, let go, gas let go.. that kind of jerk but not as "violent."
Old Oct 12, 2008 | 06:43 PM
AARONHL's Avatar
EXACTLY. So can anyone confirm what is causing that activity?
Old Oct 12, 2008 | 07:58 PM
AARONHL's Avatar
https://g35driver.com/forums/g35-sed...ml#post3522565
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Vqalexisz
Oct 14, 2015 12:48 AM
alessandro
Oct 8, 2015 09:29 AM
reaper76
Sep 20, 2015 11:59 AM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
