Have squeaking noises at cold starts before and after belt changes..
Old May 9, 2009 | 10:54 PM
  #61
g35freak86's Avatar
OEM. got them replaced at the dealer. OEM pulleys and belts were replaced at my dealer
Old May 19, 2009 | 07:33 PM
  #62
oracis2000's Avatar
Well.. i m glad to hear that I m not alone on this one.. I've recently changed both belts and I had the belt tighten to the point where you can push or pull the belt more than 1/2 inch.. and yes.. i do have mods.. but don't think that is the problem.. i still have some noise at cold start.. but my mechanic told me to bring it back to him after a tank of gas.. so about 200 miles.. to have it tighten again.. and i should be good.. and if anyone EVER SUGGEST you to put BELT CONDITIONER!! DO NOT PUT THEM ON!!...
it will not work AT ALL.. Belt Conditioner is never a solution to ANY belt problem.. its a quick fix if you are getting rid of your car tomorrow... but its guarantee to come back..
how do i know?? cos it happened to me..
(03 G Coupe, Vortech Supercharger, Skunk 2 Plenum spacer, Tein Coilover, Stillen full Cat back)
Old May 19, 2009 | 07:37 PM
  #63
g35freak86's Avatar
good to hear man. post back with results after the you get a chance to drive on it a bit
Old May 27, 2009 | 04:12 PM
  #64
BH818's Avatar
I have found the probelm! It is a bearing problem for sure! See picture
I have my uncle come over to my house and we listened to the every single bearing on the pulley. It is the ALTERNATOR IDLER PULLEY (in red on the picture) I called a local dealer (van nuys, CA) they said $300 lol I called glendale $130 something, still I lot, so I called Peoria, AZ infiniti dealer ph 866-373-4973 (Monday thru Friday 7:00 - 5:00 MST.) got it for like $65 lol. I will change it the same day I get it. and let u guys know what up
Old May 27, 2009 | 04:21 PM
  #65
BH818's Avatar
part: 11925-AL50A or 11926-AL50A they are the same thing. coupe and sedan are same pelley from 03-07
Old May 27, 2009 | 04:24 PM
  #66
BH818's Avatar
the ALTERNATOR and COMPRESSOR IDLER PULLEY are different sizes.
Old May 27, 2009 | 04:26 PM
  #67
BH818's Avatar
I checked on ebay.com Riverside INFINITI has ALTERNATOR and COMPRESSOR IDLER PULLEY but the pictures look wrong and there is no part number. If your are close to them you can go check it out.
Old May 29, 2009 | 07:04 PM
  #68
BH818's Avatar
I just got the item today I will see if my uncle wants to install it today!
Old May 30, 2009 | 03:04 AM
  #69
BH818's Avatar
SOB its still making the noise! it is either the power steering pulley or the alternator pulley
Old Jun 1, 2009 | 03:21 PM
  #70
BH818's Avatar
I though I should change to factory belts.
Old Jun 21, 2009 | 01:14 AM
  #71
BH818's Avatar
I just changed to the FACTORY BELTS and the noise STOPPED!
Old Jun 21, 2009 | 04:18 PM
  #72
bert039's Avatar
What kind of belts were you using before?
Old Jun 21, 2009 | 05:03 PM
  #73
BH818's Avatar
When I bought my car it had aftermarket belts. It was making noise at cold start so I changed them (aftermarket again) then noise was still there so i thought it was something else. I ended up changing the alt. Idler pulley noise was still there. So I got the factory and installed them myself.
The weird thing is my AC belt is also aftermarket and no sound from that
IDK I am happy its fixed NOW! I drive happy now
Old Jun 22, 2009 | 09:59 AM
  #74
bert039's Avatar
Sorry, just curious, do you know which aftermarket ones they are?
Old Jun 22, 2009 | 01:27 PM
  #75
BH818's Avatar
when I got them from a auto part store they had 2 different ones for some reason. I bought both of them. the size on one of them was a bit bigger and it had vertical and horizontal cut on it. the other just horizontal. so my uncle said use the shorter one. I think it was like $16 (shorter) and the other $25 (bit longer). So I installed the shoter one. It might have been cuz of that.
If u have that noise get the factory belt I bought it for $24.?? and installed them myself.
