Have squeaking noises at cold starts before and after belt changes..
Old Oct 20, 2008 | 02:58 PM
04G35NYC's Avatar
Have loud squeaking noises at cold starts before and after belt changes..
Hey guys, i have a problem 2 months ago my car started to make loud squeaking noises at start up when it got cold, when i turn on the car to warm it up, this annoying noise started coming from the belts on the left side, i thought it was the belts so i decided it's time to change them because apparently the first owner never changed them for 35k miles that's when i bought the car at the dealer and drove the car till 41k miles and this stupid loud noises stated to happen even after i changed the belt it's still going on like something is loose but it's not.
After i warm it up and drive it i still hear that stupid loud noise even after i hit the gas and then slow down the squeaking noise starts again on the street, but after i drive it on the highway for like 15 min it goes away and its fine. This stupid **** happens only when the car sits for like 5 Hrs or overnight turn it on next day and the the noise comes back again. So i have to ask did anyone ever have this problem? I'm thinking some of the stock pulley's are ****ed up. Thanks.
Old Oct 20, 2008 | 04:06 PM
RaginRaj11's Avatar
i have the exact same problem. Im guessing either the belts are too tight or too loose.
Old Oct 20, 2008 | 04:48 PM
04G35NYC's Avatar
^ glad to hear i am not the only one but not glad having this stupid problem nor some one else has to deal with it, i had a shop tighten the belt's and mid loose them nothing changed. Can it be the Idle pulley is going?
Old Oct 20, 2008 | 04:56 PM
Deezflip's Avatar
yep, too tight or too loose.
Mine only happens once or twice that I didn't bother adjusting it. Now that i think about it, it only happened when i had my A/C on at start-up. More likely, it's probably that belt with the A/C compressor and not the other one.
I was thinking a tension gauge would help, but with the way belts stretches. It'll only be a matter of days until the tension is off again. Looks like it's one of those ten million things where the G is so picky.
Old Oct 20, 2008 | 04:59 PM
uf20wop's Avatar
i have this too, i just assume they're a little too tight or loose, i'm not too worried about it =/
Old Oct 20, 2008 | 05:01 PM
04G35NYC's Avatar
^ Thanks guys, i guess i will have to deal with this till it gets warmer
Old Oct 20, 2008 | 08:37 PM
NismoG35S's Avatar
bad tensioner maybe?? i wouldnt think a squeal is normal .. only thing is maybe since its cold out when u park ur belts are pretty hot and over night they collect condensation so when u start it up its squeals for a bit till the water is dispersed? jus turn ur radio up 8-) lol jk gl
Old Oct 20, 2008 | 08:51 PM
fbpem1's Avatar
yes there is a tension gauge and a strech gauge i have them both at work made by kent moore, its a nissan/infiniti special tool. its easy to have them too loose nissan/infiniti belts like ot be like a banjo string.
Old Oct 20, 2008 | 09:14 PM
04G35NYC's Avatar
^ where can you buy this tool and where do you find out what tensions it supposed to be? Thanks a lot.
Old Oct 21, 2008 | 07:19 AM
fbpem1's Avatar
its in the esm under SDS (service and data specs) and any local tool dealer who sells kent moore products can get it for you IE: Snapon, Matco, etc... if i have time to day i'll pull them out of my tool box and get the part numbers off of them.
Old Oct 21, 2008 | 06:19 PM
04G35NYC's Avatar
^ Thanks.
Old Dec 3, 2008 | 07:38 PM
bythabay's Avatar
I use one made by OTC:
http://www.denlorstools.com/home/dt1...e_otc6673.html
Old Dec 23, 2008 | 12:21 PM
AARONHL's Avatar
Hey guy, i have a problem 2 months ago my car started to make loud squeaking noises at start up when it got cold, when i turn on the car to warm it up, this annoying noise started coming from the belts on the left side, i thought it was the belts so i decided it's time to change them because apparently the first owner never changed them for for 35k miles that's when i bought the car at the dealer and drove the car till 41k miles and this stupid loud noises stated to happen even after i changed the belt it's still going on like something is loose but it's not.
After i warm it up and drive it i still hear that stupid loud noise even after i hit the gas and then slow down the squeaking noise starts again on the street, but after i drive it on the highway for like 15 min it goes up and its fine. This stupid **** happens only when the car sits for like 5 Hrs or overnight turn it on next day and the the noise comes back again. So i ask did anyone ever have this problem? I'm thinking some of the stock pulley's are ****ed up. Thanks.
Did you fix this problem yet????? I have the same exact problem!!!!!!
Old Dec 23, 2008 | 05:01 PM
04G35NYC's Avatar
^ it got a little better, but i still have it. I didn't buy the tool above your post yet to make with in the specs. I will update when i will find out what is making the noises if it's not the belts.
Old Dec 23, 2008 | 05:16 PM
joedaddy1's Avatar
might want to try wiping the belt side of pulley..
there might be "excess" grease that's making your belts slip.
