Oil Recommendations?
Old Nov 3, 2008 | 12:58 PM
Driver99's Avatar
I have a '08 G35 sedan and am coming up on my 3rd oil change at 11,250 miles. The first 2 changes were done by the dealer for free and now I'm on my own. I was thinking of going to synthetic oil and doing it myself. Can anyone tell me if its difficult to first do the oil changes and second what brand of oil is good. I also wanted to know if I should stick w/ the OEM oil filters or go w/ aftermarket.
Old Nov 3, 2008 | 09:03 PM
marty315's Avatar
Lots of threads with plenty of posts on here about this topic. Search will ultimately be your friend. I've got an '06 and it was very simple to change the oil for me. I'm using Mobil One Synthetic 5W30 with a Mobil One Oil Filter and have been very happy with the results so far (just changed it about 3,000 miles ago). I had trouble finding the crush washer used for the oil reservoir seal and used a rubber one. I've since had another user post a link to the washers and I purchased several. Again, the search function is your friend.
Old Nov 4, 2008 | 12:33 AM
Driver99's Avatar
Thanks for the response, I figured there would be a lot of threads on this subject but all the ones I came across seem to do w/ oil consumption issues. I'm looking for just suggestions on what type of oil and filter people are using for there G's. Also I noticed that the manual lists that the vehicle takes 8 quarts of oil when changing, on other threads I read 5 quarts. Can anyone confirm this?
Thanks again.
Old Nov 4, 2008 | 01:41 AM
ttrank's Avatar
Grocery getter
The VQ ueses 5qts. I'm a big fan of M1.
Old Nov 4, 2008 | 01:25 PM
Canadian's Avatar
Canada, eh?
I use Amsoil. You can't go wrong with Amsoil/Mobil 1 or any of the expensive ones, such as Motul. Also, DIY oil change is easy. Just need some ramps, 10mm and 14mm wrench, and an oil pan. Don't forget the oil and filter
Old Nov 4, 2008 | 01:47 PM
Swivel's Avatar
Moderator
Amsoil and Wix make the other high-quality oil filters. Don't use Fram. The Nissan one is fine as well.
Old Nov 4, 2008 | 04:06 PM
bhancz's Avatar
mobil1 5W30
Old Nov 4, 2008 | 04:49 PM
(>")> G35's Avatar
Motul 8100, been using it since my second oil change.
Old Nov 6, 2008 | 06:24 PM
elior9557's Avatar
royal purpel.... 10w-30!
Old Nov 6, 2008 | 06:30 PM
uf20wop's Avatar
mobil 1 5w30 for me
Old Nov 7, 2008 | 11:38 AM
elior9557's Avatar
to UF20WOP
dud i used to put this cinda oil in my car... (mobil 1 5w30), then a friend of mine told me try to put royal purpel 10w30, i called infinity, checked if that k to put that oil, they sed yea, i went bought the ****ing oil.... u can really but really feel a difference!!!!
its like the car is smoother, changing shifts and everything.
Old Dec 27, 2008 | 02:17 AM
HiTechOilCo's Avatar
Would not be recommended to use in a 2008 vehicle requiring an API SM rated motor oil to maintain the warranty, as RP 10W-30 is an old API SL rated motor oil from 5 years ago. Read the oil bottle.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
UT G35
Sep 3, 2015 03:58 PM
