Idle pulley delete w/ DM2 spacer
Old Oct 23, 2009 | 03:01 PM
  #31
Andrei's Avatar
Originally Posted by GreenGoblin
Andrei you really need to put in the spacer, if you keep running the belts with tension on them and no spacer or idler you can cause potencial damage to the treads in the block where the bracket bolts up. If you are having trouble getting the spacer in crack loose the 2 bolts that go through the bracket in the block to give you more wiggle room.
That does make sense. I guess I'll drop it in soon.
seagrasser
May 3, 2022 09:43 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
linedr89
Aug 17, 2015 05:11 PM
