Custom 3.5" (90mm) CAI in the works
Old Dec 16, 2008 | 02:37 PM
  #31
_jb's Avatar
_jb
Photographer
Your first post makes it look like you are assembling the 3.5" CAI for a normally aspirated G35, and later transforming to a boosted engine. NA engines suck the air instead of having it rammed down the CAI, so I would think the whole pipe should be the same size for an NA engine.
I have an NA engine and plan on staying NA. I have looked into bored throttle bodies and can post some info if you are interested. I am leaning towards bored OEM throttle bodies because I want to continue to use the OEM drive-by-wire. I would love to find a larger throttle body that would integrate with the OEM drive-by-wire.
Are your plans to keep the OEM throttle body while you run NA? It would make sense for you since you plan to go FI in the future.
This is a great thread... I'm interested to see your results.
Old Feb 28, 2009 | 10:09 PM
  #32
_jb's Avatar
_jb
Photographer
Any updates here?
Old Mar 1, 2009 | 01:39 AM
  #33
Andrei's Avatar
None yet. Still waiting on my shop to buy a damn spool gun. But right now they in the process of moving again to a bigger location. I asked FP to let me rent their equipment but they said no.
I'm actually going to rent some welding equipment and get this done. This place might have it. http://www.rent-allplaza.com/Equipment_Rentals.html
Old Mar 2, 2009 | 12:42 AM
  #34
rcdash's Avatar
As George pointed out, I don't think you can use a stock MAF sensor in a larger housing and expect it to work. You will have to reflash the ECU to recalibrate the MAF sensor. The MAF sensor voltage output is a function of airflow but the housing needs to be exactly the same dimensions for the voltage calibration to be accurate. Injected does not use the MAF for anything other than to keep the stock ECU from throwing CELs. Their Haltech unit (EMS) is using a MAP sensor to control fueling.
You may want to run it by the folks at UpRev. They will get you squared away on what you need to do to get this working safely.
Old Mar 2, 2009 | 02:36 AM
  #35
FenixL1P's Avatar
changing the diameter of the pipe will affect the fluid dynamics of the air through it thus affecting the maf sensor.
Old Mar 2, 2009 | 02:59 AM
  #36
GTM's Avatar
GTM
I tried Raj, I tried... He will find out when he starts the car
Hint: Reduce the diameter of the pipe were the MAF sensor will be located to the same diameter as the OEM MAF housing, or retune your ECU.
-George
GT Motorsports
Old Mar 2, 2009 | 11:05 AM
  #37
rcdash's Avatar
-George
GT Motorsports
Nothing wrong with learning the hard way I suppose. A+ for initiative.
Old Mar 3, 2009 | 08:49 PM
  #38
xXHotelCrazyXx's Avatar
Lookin good, always feels good to fabricate something that not many have done.
Old Mar 5, 2009 | 04:43 PM
  #39
Andrei's Avatar
I went ahead and bought a spool gun for Speedywrench.com. I also might be taking partial ownership.
I might have this done next week on the weekend.
Old Mar 5, 2009 | 04:59 PM
  #40
Jeff92se's Avatar
Red Card Crew
Is this for the MAF? Size? Brand? Do they have one for the oem maf?
Old Mar 5, 2009 | 06:42 PM
  #41
OCG35's Avatar
looks like a throttle body spacer with injectors.
Old Mar 5, 2009 | 06:47 PM
  #42
Jeff92se's Avatar
Red Card Crew
Probably right. TB spacer with vacuum ports for signal. Not injectors LOL
  #43
SDGeneralCounsel's Avatar
+10000.
I'm sceptical as well as to the gains/benefits, but nothing can be said until this is competed and testing.
Old Mar 5, 2009 | 07:13 PM
  #44
OCG35's Avatar
okay vacuum ports - I was thinking it was for NOS injection or meth injection or something... I dont use it so I'm not too familiar... anyway - not maf sensor housing.
Old Mar 12, 2009 | 01:14 PM
  #45
Andrei's Avatar
This came in today. 2 reducers and some more tbolt clamps to use the stock MAF housing. I'll have this done this Friday or Saturday.
Something I pulled off my first car after I totaled it. Might be useful.
