Custom 3.5" (90mm) CAI in the works
Old Apr 15, 2009 | 11:47 AM
  #61
Andrei's Avatar
Originally Posted by _jb
Big pipe looks super!
Where did you get the reducers and clamps?
I need to polish the pipe and change the bolts from the clamps. It was a quick and dirty install. I got the clamps and reducers from Hose Techniques. They have great customer service by the way.
Old Apr 15, 2009 | 03:43 PM
  #62
_jb's Avatar
_jb
Photographer
Thanks.
Old Apr 19, 2009 | 12:44 AM
  #63
Andrei's Avatar
Finished the install today the right way. Now I need to detail the engine bay and get that ****ing pollen out.
Old Aug 10, 2009 | 02:37 PM
  #64
Andrei's Avatar
I ordered this to complete the intake. I have another 3.5" 90 degree L pipe coming and I'll bring the intake behind the grill when I have time.
304 ss is for something else. The aluminum sheet is to make support brackets for the pipes.
Old Aug 23, 2009 | 02:32 PM
  #65
Andrei's Avatar
Today I relocated the horns and test fitted the pipe and intake. Everything fits perfect.
Next month I'll take the bumper down and drill through the radiator support and have this finished properly. I'll try and keep it looking like the 350z intake hole and I'll use a 90 degree silicone coupler in black to match the black radiator support.
Old Aug 23, 2009 | 03:09 PM
  #66
OCG35's Avatar
^^^ If it wasn’t blocking so much airflow to the radiator I would really like this idea
Old Aug 23, 2009 | 06:14 PM
  #67
WhosUrBuddiee's Avatar
I dont get the point of this. You still have a small throttle body.
Old Aug 23, 2009 | 06:17 PM
  #68
Kits flow more than enough air for a stock block. Why dont you spend the money on internals?
Old Aug 23, 2009 | 06:28 PM
  #69
PTownG's Avatar
so we have a stock TB, a stock MAF, and a big fat pipe connecting the 2. Now you intend to run another big fat tube to relocate the air filter directly behind the grill where it will get totally soaked if you ever drive in the rain and will get equally soaked when you wash the car.
Brilliant.
Old Aug 23, 2009 | 07:25 PM
  #70
Andrei's Avatar
I am when I FI the car. I actually plan on buying a used engine and building that.
Brilliant.
It's going to have a shield over the side of the filter that is facing the grille.
and I think I can use the MAF and TB from the VQ40. But the TB on the VQ40 is only .25" bigger.
Old Aug 23, 2009 | 07:49 PM
  #71
03threefiftyz's Avatar
Sorry, but I think this is a waste.....without going to a larger maf at the very least this won't produce. Noble idea and attempt to be different, but not well planned out.
There is more to a productive intake then just volume of air it can flow. You need to factor in resonance, air velocity, and pressure as well.
Old Aug 23, 2009 | 07:59 PM
  #72
SDGenius's Avatar
i think the effort woulda been been better used on a "power chamber" style setup, could duplicate the pressurization effect that the OEM intake.
Old Aug 23, 2009 | 08:20 PM
  #73
I am sorry but now this just became even more pointless. You put a giant tube and filter behind the grill (where it blocks the majority of the radiator) for increased flow. But you are covering the huge filter with a huge metal shield??
So you are going to have your filter sandwiched between a hot radiator on one side and hot piece of metal on the other? All of this is going though a 2.25 inch stock throttle body? Am I missing something here?
Old Aug 23, 2009 | 08:23 PM
  #74
Not too mention going through a filter without a velocity stack and a 70mm maf before even hitting the secondary tube. I would be utterly surprised if this set-up came even remotely close to a stock box. My guess is this is a ~5whp loss over stock.
Old Aug 23, 2009 | 08:49 PM
  #75
PTownG's Avatar
too stupid to continue.
unsubscribed.
