Intake Manifolds?
Old Dec 22, 2008 | 02:22 AM
tomuchboost's Avatar
Intake Manifolds?
From all the intake manifolds which 1 gives PROVEN RESULTS the most HP gain in NA ? I don't consider ITB to be a choice.
Old Dec 22, 2008 | 09:12 AM
jonnylaw's Avatar
You're user name is "tomuchboost" and you want to know what intake manifold gives proven NA gains?
Check Motordyne spacer. What year/engine is your G?
Old Dec 22, 2008 | 11:35 AM
Q45tech's Avatar
Most people don't realize that a NA engine already receives ~~14.7 PSI boost from earth's atmosphere. At WOT there is a little less than 1.0 psi restriction so 13.9 PSI [corrected for barometric pressure variance] is more accurate.
Old Dec 22, 2008 | 01:09 PM
joe603's Avatar
It's not "boost" if its atmospheric pressure at sea level....The term "boost" implies that there is added pressure on top of regular atmospheric pressure...
Old Dec 22, 2008 | 09:13 PM
Tollboothwilley's Avatar
The motordyne spacers (5/16") are the most commonly used spacer. The Kinetix has the best gains (the SSV) but they aren't worth the cost unless you go FI. Kinetix V+ plenum is a good choice. I went with the BLOX, which is a 5/8" spacer.
Old Dec 23, 2008 | 10:36 AM
Yes, it's easier for me to keep my username for both here and supraforums and the username is for my supra :P
Anyways
I got a 2004 g35, non revup. I did review the motordye and I know it works just I'm looking for a manifold for show and I don't want a no go show item :P
And boost will follow soon
Old Dec 23, 2008 | 12:15 PM
str8dum1's Avatar
if boost will follow, no reason to get any spacer/manifold now then. Unless its a cosworth becuase people are making well over 600 without them.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
