mrev 2 problems????
Old Dec 30, 2008 | 09:42 PM
G3.5-Unit's Avatar
mrev 2 problems????
i just put it on yesterday, and now i noticed the car idles very rough when im just sitting there idles jumps from 750 to 500 then up to 800 its not stable im getting its getting more air now but im not sure so anyone can ya help me out????
Old Dec 30, 2008 | 09:49 PM
rpm06g35's Avatar
vac leak bro. find the leak and go from there.
Old Dec 30, 2008 | 09:50 PM
G3.5-Unit's Avatar
yea i looked for any hoses that wherent hooked up but i can find ****!!
Old Dec 30, 2008 | 10:08 PM
citymunky's Avatar
You have a leak somewhere, did you torque the manifold bolts in the right order?? (60in-Lb's-> then 80in-Lb's-> than 100in-Lb's)
Also check your manifold gasket and make sure it is not kinked or bent.
Old Dec 30, 2008 | 10:18 PM
G3.5-Unit's Avatar
let me ask you what if i turned the gasket to like upside down and theres a piece sicking out i see part of the gasket its like a lip , i just checked it could that be the problem?
Old Dec 31, 2008 | 04:33 AM
Joe_Camel's Avatar
take it apart and put it back together carefully, that's probably it.
Old Dec 31, 2008 | 08:41 AM
rcdash's Avatar
check around the oil filler cap...
Old Dec 31, 2008 | 09:08 AM
Glex25's Avatar
Administrator
^+1
People always overlook the rubber cup around the oil cap that gets caught
when putting back on the upper plenum
Old Dec 31, 2008 | 09:10 AM
Hi-TechG35's Avatar
^+10000 on that I remember when I did that and my car sounded like a plastic bag caught against a fan. Also if you have a spray bottle you can mist the plenum to see where the leak is comming from.
Old Dec 31, 2008 | 10:29 AM
Texasscout's Avatar
I have used starter fluid to find vac leaks. Spray VERY short bursts around the plenum. If the idle goes up, you have found your leak.
Old Dec 31, 2008 | 04:33 PM
djamps's Avatar
I usually use carb cleaner because it evaporates and doesn't leave a mess.
Old Dec 31, 2008 | 06:33 PM
Texasscout's Avatar
SF is nothing but either with a tiny bit of oil.
Old Dec 31, 2008 | 10:29 PM
citymunky's Avatar
Cool trick
Thebaws11
Jul 2, 2021 11:36 AM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
wuzz-upp
Oct 3, 2015 04:21 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
