riddle me this !!
Old Jan 20, 2009 | 07:48 PM
jaymac's Avatar
riddle me this !!
03, 6mt coupe. went out to defrost snow. ran the car for 20 minutes in the driveway. when I got in it to leave i noticed it running low RPM's under 500. thought maybe nothing and drove to the store and back. when I get home it's still doing it. i can feel the motor running rough, but no engine codes . WTF.. checked the motor, oil is good. any ideas?
Old Jan 20, 2009 | 08:01 PM
Canadian's Avatar
Canada, eh?
Are you sure it is below 500? Right at 500 is where my idle is. I doubt you can tell a difference from 10-20 rpms. Take a picture of it.
drunkin master's Avatar
Do you have any mods like intake, headers,
You should try a search...you will probably find a solution.
if all else fales, try to reset the ecu.
Old Jan 20, 2009 | 08:35 PM
jaymac's Avatar
did a search no results yet. I know that outside temps & air temps can affect sensors. this is the first really cold I'v had since buying the car. there was 6 inches of snow on it. the rpms re floating at the first line above 0 it's never been that low, it's usually at the second line. also no engine mods yet.
Old Jan 21, 2009 | 04:32 PM
AARONHL's Avatar
Clean your throttle body if you have not done so already. Change the air-filter too.
Old Jan 22, 2009 | 08:00 PM
Infern0's Avatar
Here's a good thread on that:
https://g35driver.com/forums/intake-...gine-idle.html
Old Jan 22, 2009 | 09:23 PM
Red_G35's Avatar
while you're cleaning your TB/filter make sure you clean the MAF too.
Winged Wheel
Canada
May 20, 2011 11:02 AM
nismonkey
West
Apr 13, 2011 05:43 PM
