$60 for labor charges.. is this a great deal?
Old Jan 21, 2009 | 04:42 AM
Cali_G35's Avatar
Quick question: my local body shop quoted me $60 for labor to change my auto transmission and my rear diff. Is this a good deal?
Old Jan 21, 2009 | 05:02 AM
JBF's Avatar
JBF
fluid and oil? you might be able to find a better deal somewhere else
or change the actual tranny and rear diff? great deal! usually costs around 500-600 in labor
Old Jan 21, 2009 | 05:05 AM
Cali_G35's Avatar
i have to provide all the fluids, nissan j-matic auto tran + nissan rear diff. $60 for the labor and labor only..
Old Jan 21, 2009 | 05:14 AM
JBF's Avatar
JBF
I think the average labor rate in the US is around $70 an hour so if they believe they can do it in an hour, you should be alright. I looked it up. But when I changed mine on my truck, it took the mechanic almost two hours due to waiting on COMPLETE drainage. The guy charged me for only an hour labor since I argued with him that smoking cigs and reading the paper while the fluids were draining wasn't sufficient "labor"
If you're cool with the guys at the body shop, I say go for it.
Old Jan 21, 2009 | 10:36 AM
canucklehead's Avatar
i wouldn't recommend going to a body shop for mechanical/service work. typically i'd say leave mechanical/service work to mechanics/service techs and body work to body shops.
but that's just me...
Old Jan 21, 2009 | 10:42 AM
Swivel's Avatar
Moderator
The rate sounds okay if they know what they're doing, can do it in an hour and drain both properly. If it suddenly turns into 2-3 hours, it's not such a great deal. Find some DIY's on the board here, see what goes into it and judge for yourself. Better yet, do it yourself!
Old Jan 21, 2009 | 11:32 AM
PAIXAO's Avatar
Damn, labor rates out here are well over $120 an hour at most places. If someone quoated me $60 I would be worried about the knowledge of the guy working on my car.
Luckily, I have a connect at a local Nissan dealership. Any work I want or need done gets done on the side. I pay a tech $30/hr...
Old Jan 21, 2009 | 01:07 PM
G SEDAN's Avatar
i paid my friend on the side (who's nissan tech) $100 to do a trans flush, differential drain and fill, and an oil change.
I provided all the fluids, and this was with a heavy discount because he was my friend.
$60 for all that is great, granted they know what they're doing. Which is probably the case, because drain and fill on the trans and differential fluid takes very little mechanical knowledge.
Old Jan 21, 2009 | 02:06 PM
TheTick's Avatar
$60 bucks is a fair price.
Old Jan 21, 2009 | 05:15 PM
Mustang5L5's Avatar
Body shops sometimes employ mechanics. When a car gets cracked, sometimes more than just sheet metal gets broken. Changing fluids isn't that tough to do but it's up to the OP to determine if the shop is competant enough to perform such a task.
Old Jan 21, 2009 | 06:26 PM
ttrank's Avatar
Grocery getter
That's a good deal. I would charge someone ~$50 to do it at my house.
Old Feb 12, 2009 | 12:24 AM
aannddyy's Avatar
That is a good deal..
11bEMT
May 27, 2022 03:13 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
newg37
Jul 26, 2015 09:32 AM
