fuel filter? differential lubricant?
Old Jan 29, 2009 | 12:11 AM
ws-6driver's Avatar
i was wondering if anyone knows how to get their hands on a replacement fuel filter for an '03 g35 sedan. i've looked around and i couldn't find anything. also, i can't find information on what lube to use when replacing the rear differential lubricant and if there is some type of additive you are supposed to put in the lube, like limited slip lube. thanks.
Old Jan 29, 2009 | 12:27 AM
canucklehead's Avatar
use gl-5 fluid in the diff. you can also use an approved friction modifier. check your owner's manual. it specs the fluid required.
the manual also states the fuel filter as a non-serviceable maintenance item. i suppose if you are high-mileage you could replace it as a preventative measure. but unless you are noticing hesitation or other symptoms of a clogged fuel filter i wouldn't bother swapping it. again, check with the manual.
Old Jan 29, 2009 | 12:35 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
The fuel filter is part of the fuel pump in the G, so you either replace the whole thing, or you dont do it at all.
Rear diff fluid is GL-5 and you shouldnt need a friction modifier as GL-5 is made for limited-slip applications last time i checked. Just read the fine print on the bottle and make sure it says approved for limited-slip differentials with no modifiers.
-GP-
Old Jan 29, 2009 | 02:04 PM
ttrank's Avatar
Grocery getter
You can get a fuel filter from the dealer. Grant is right, it's part of the fuel pump assembly and takes some time to swap. I did mine a while back when I put in a different pump. I use redline in my diff, 75w90.
Old Jan 29, 2009 | 02:42 PM
Swivel's Avatar
Moderator
For your diff you could also use Amsoil SEVERE GEARŽ Synthetic 75W-90
Old Jan 31, 2009 | 09:23 AM
ws-6driver's Avatar
sweet! the filter is a part of the pump! what other ways will dealers find out how to make it harder to maintain your car yourself? i thought it would be ok to use 75w90 synth. that's what i put in my '00 t/a diff. thanks for the help. i'm probably gonna have someone else change my wife's fuel filter.
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
Hogbone
Sep 28, 2015 06:44 PM
