Return Fuel System Guys... IN HERE!
Old Feb 3, 2009 | 10:24 AM
GreenGoblin's Avatar
The goblin resurrection
I would just redo it, I cant see the pics at work. You can buy the correct an fittings and make a one piece return line.
Old Feb 3, 2009 | 10:38 AM
ttrank's Avatar
Grocery getter
I'm not at work and still can't see the pics???
Sounds like the line needs cut an inch back and a new adapter installed. I had a problem like that with mine back when I had a stage 1 kit. You can try to tighten it but you may need a new one.
Old Feb 3, 2009 | 11:32 AM
Glex25's Avatar
Administrator
You can't post pics directly your gmail account.
Do something like flicker or photobucket
Old Feb 4, 2009 | 07:07 PM
str8dum1's Avatar
where it is leaking on that connector? at the threads of the connection or where the hose was crimped to the AN fitting?
either way www.anplumbing.com is good source. i ordered a lot from them in the past
Old Feb 4, 2009 | 08:04 PM
So this is the feed from the metal line to the regulator? Or is the return? Either way first thing an fittings are not ment to have teflon tape this will inface have a higher chance for them to leak. If this is the return line I suggest buying some line and making it one piece back to the tank.
Old Feb 5, 2009 | 08:03 AM
str8dum1's Avatar
well measure the inside diameter and call anplumbing.com
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
Rhinos7777
Sep 6, 2015 05:36 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
