cold knock on start up
Old Mar 25, 2003 | 08:54 AM
m1dtom's Avatar
has any one noticed a cold start knock.once in a while on cold start, i get like a half second knock either from eng or tranny. i use mobile one and factory filter.
i have about 2700 miles and auto trans.
thanks tom
Old Mar 25, 2003 | 11:43 AM
OvaYahead's Avatar
Re: cold knock on start up *DELETED*
Post deleted by ovayahead
Old Mar 25, 2003 | 11:50 AM
stewa101's Avatar
he just said he has and auto
Andrew
2003 coupe 6MT blue premium aero (since 3/9/03)
Old Mar 25, 2003 | 12:28 PM
OvaYahead's Avatar
oops I was just eager to reply
BS G35C 6spd navi/aero/prem
Old Mar 25, 2003 | 02:05 PM
stewa101's Avatar
It's alright, wasn't pickin on ya.
Andrew
Old Mar 25, 2003 | 04:22 PM
Msedanman's Avatar
O.F. Administrator
Yes I get a little clattering sometimes at cold startup. Only for a second or less. I noticed the same sort of noise in my Sedan and my 2k2 Max. As far as I know it's normal.[img]/w3timages/icons/smile.gif[/img]
<font color=red>GSM</font color=red>
Old May 26, 2005 | 01:06 PM
barrios35's Avatar
That is weird happens to mine once in a while but just as the key is turned almost like something under the hood. The sound is just one knock. Any ideas on why or what it is? I am assuming it can't be normal if it only happens at certain times.
Old May 26, 2005 | 03:19 PM
ballisticus's Avatar
What weight Mobil 1? Hopefully you are using 5W/30 and not the 15W/50. The thick stuff is not what you want in a VQ.
Old May 26, 2005 | 08:03 PM
RussB's Avatar
probably just valvetrain noise while the oil is still circulating throughout the engine. a lot of cars sound like pure a$$ when they're first started in the cold.
Old May 29, 2005 | 04:27 AM
Hooman6MT's Avatar
20 Year Member
if it's for a few seconds in the morning, I wouldn't worry too much about it. If you get the same noise sitting at a red light after driving to work, the I'd worry. You may want to check your oil level and make sure you're not low. Our cars are known for consuming oil, well I don't know if it's known...but my car does.
Hooman
Old May 29, 2005 | 11:37 AM
g35_6gear's Avatar
The timing chain system is hydraulic. It takes a second for the oil pressure to come up and tighten up the tensioner...so the chains are making the noise.
Old Jun 19, 2005 | 03:11 PM
JEWBU's Avatar
i get the same thing in my Lexus sc300
Old Jun 20, 2005 | 08:47 PM
G35TR's Avatar
If you get a knock, or an almost grinding noise sound for about a second, right after starting the car (on a cold start), that is normal. It's the timing chain, running through a tensioner. Once the chain pulls some oil through it, it goes away. But it's normal and nothing to worry about.
chinee
Jun 10, 2024 07:48 PM
andyg35c1
Aug 29, 2015 03:37 PM
rping
Jul 26, 2015 09:53 PM
Thaaa_king
Jul 18, 2015 05:56 PM
